Question about Jabra BT350 Bluetooth Headset Headset
After charging earpiece my phone will not connect
I have recharged my earpiece and now my razor phone will not connect to it.
  • 9 more comments
  • imtofly Jan 03, 2008
    i have a bluetooth in my wont connect to my phone
  • Anonymous Mar 03, 2008
    how do you select the discovery mode for the headset? When I tryed to have my phone discover the bluetooth it could not find it. It said to put the blue tooth in the discovery mode. How do I do that?
    how do i put my headset in the discovery mode? I have a new moto cell phone from verizon. When I try to discovery my bluetooth headset it says put your headset in discovery mode.
  • eunie Mar 07, 2008
    For some reason my earpiece disconnected from my razor phone and i forget hoe to pair them again
  • Anonymous Jun 25, 2008
    CONNECT TO PHONE
  • simplus Aug 08, 2008
    My Palm Treo cannot find the Jabra earpiece. Help
  • dogersrok Aug 21, 2008
    when i press connect i just won't connect
  • Anonymous Aug 22, 2008
    how do i use the bluetooth piece after charging, it how do i get it to work with my phone.
  • Anonymous Aug 24, 2008
    I have the Moto Q 9 and can not get my Jabra ear piece to connect
  • Anonymous Oct 07, 2008
    i have a motorala w385 and the headset eill not connect
  • Anonymous Mar 14, 2014
    The earpiece of my headset seems to have stopped working, the microphone is working fine. Any ideas? Thanks!
I WOULD TRY RESYNCING IT ALL TOGETHER. REMOVE IT FROM YOUR PHONE AND PAIR IT UP AGAIN.
Posted on Jul 10, 2007
My razor stopped working. The charge level lights on **** of razor blink when I turn razor on.
Hi -
How old is your razor? It's possible that the battery's shot.
One of the problems with rechargable batteries is that they have "memory". If you put them on a charger when, say, they're only at 50%, then over time they'll start thinking that 50% is actually 0%. This is why it's often advised to run your appliance down to nothing (your razor, your laptop, your rechargable flashlight) before putting it on the charger.
Alternatively, your charger might be acting up. Best recommendation would be to take your razor (and charger) to a shop to be tested. This is an expensive razor, and if you like it, it would make more sense (and be cheaper) to get it fixed rather than toss it into the land fill & buy another.
Good luck...
Mar 02, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Razor will not take a charge, will only function when plugged in.
Sounds like the batteries are shot. They can be replaced if you're handy with a soldering iron.
Apr 30, 2010 | Norelco Rechargeable Cordless Men's Razor...
I can`t hear anyone, mute is stuck on my razor phone
i dont think is the mute its probably the earpiece
you could find most of the parts in ebay.com
Mar 26, 2010 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
I found the solution in the online manual from motorola. I have included the website below: http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Aug 17, 2008 | Motorola Mobility H700 Wireless Headset
How to charge battery
I think it recharges by taking some power from the computer when it is connected. I also use a cell phone charger from the razor series of phone.
Jul 13, 2008 | Naxa Electronics Naxa Detachable PLL...
Razor battrey
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Jul 08, 2008 | Motorola Mobility RAZR V3
Please
try to change the battery. for long life of battery, recharge your battery only when you are left with 15-10% of charge.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
H700 Loosing Charge Quickly
I think the normal talk time is around 6 to 8 hrs if your battery is holding less you probably have a unit with a faulty battery
how old is your headset
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
586 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
