ASUS MOTHERBOARD P5B-MX WIFI WON'T DISPLAY
HiI just bought an Asus P5B-MX WIFI motherboard with intel core 2 up to 64 bit and 1gb ram all installed.
The leds and internal speaker are all connected.
The power supply is an Atx 450w.
All is connected well and i use the onboard vga.
Dvd and Hard Disk are connected.
THE PROBLEM:
When i switch the power on ,every thing runs normaly, the Green Led is on for power ,the dvd open and close and the cd inside is spinning ,the HD is running (I can sense it),
the cpu fan is running but THE DISPLAY is not showing any activity and the whole thing doesn't boot on post .
What is the problem?
I tried to take off the Ram stick and the speaker went beeping 3 times (1 long,2 short),
when i tried to restsrt,
when i put the ram again, the speaker stops
i can not figure out what is hapening ,
the problem is that the normal start up of the bios is not booting,or may it is booting but i can not see it because there is no diplay ,and above all there are no normal bips comming from internal speaker(the only time it beeps is when i take the RAM off, to tell me that it is off.
  • camlamm Dec 14, 2008
    Thanks.Nothing doing.
    I will try to return the Board to the vendor while it is still on warranty.
    I think this is the best solution before something else go wrong also.
  • 95 Answers
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Posted on Dec 13, 2008
I install new processor of intel e7500 core 2 due...but display is not shows........please send me quick reply.....
ASUS P5GV-MX motherboard only support
Intel Pentium 4 / Celeron processors. It will not support Core 2 Due processor.
Thanks for using FixYa.
Jun 15, 2011 | ASUS P5GV-MX Motherboard
Asus motherboard p5b-mx wifi won't display vga
this can be caused by a number of issues the leading being RAM (no post beeps at all). before you do anything else pull all existing RAM and install a KNOWN GOOD STICK in their place and try again.if that doesn't work try resetting the mb (see the owner manual on how to do that) bios settings to defaults (this generally selects onboard video). if you have an installed video card within the system also remove that (even though you aren't using it). is that memory compatible you have there with the board? if its too slow the stick may be fine but mb may not "think" so. do you have keyboard "flash"? is the hard drive indicator constantly lit? how about cdrom drives and/or floppies? can you eject same? all this points to incompatible or "bad" memory as the main culprit.
Dec 12, 2008 | Computers & Internet
ASUS P5B-MX/WIFI MOTHERBOARD : NO DISPLAY
If you just bought it, I suggest you contact the store where you bought it to claim the warranty.
If you keep trying to find solution, you might do something that void your warranty.
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
On barebone asus p5b-mx 1st try won't boot display but led is on
Hi There,
Disconnect the hard drive ribbon cable from the mother board and try again. carry on disconnecting each component at atime and trying again. Leave the video attached. this is going to be a process of elimination. sooner of later you will find out where the problem is.
My personal feeling is that the hard drive is connected incorrectly.
Let me know if you want further help.
Regards,
Philip
Dec 09, 2008 | ASUS P5B-VM DO Motherboard
Psb-mx/wifi
The problem - I guess - is that this CPU is not recognised correctly by the board. To solve it, just update to the latest BIOS, using either AsusUpdate or manually from www.asus.com
Dec 06, 2008 | ASUS P5B Deluxe/WiFi-AP Motherboard
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
Computers & Internet Logo
532 people viewed this question
David Payne
David Payne
