Question about Canon PIXMA MP150 All-In-One InkJet Printer
Blinking "E" and "5"
I have "E" and "5" flashing (back and forth between them). I've lost manual, so I'm not sure what they mean. I'm pretty sure the "E" is simply for "Empty" since the "Black Ink" and "Color Ink" cartridge lights flash with it--I just want to make sure.
    Novelist:
  • 59 Answers
Hi barneyfan -
You're absolutely right - E5 means that the ink is empty (or that the ink can't be loaded for some other reason, such as an incompatible cartridge or improper installation)
For your reference, here is the complete list of error codes for the MP150 with brief descriptions:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
I have a nissian xterra 2004 and my engine soon light has been on for a while now. But today it started blinking and then the car started shaking back and forth. It's pretty cold today 14 degrees which...
The check / service engine light means there is a problem with the performance the engine computer has detected. The flashing light means the problem is serious.
You need to have the engine computer checked for trouble codes to proceed.
Feb 19, 2015 | Cars & Trucks
How do i repair green blinking light in motherboard and not powering up?
Why would you want to try to repair a working green LED?
But you need a manual, to check what the blinking light means. See how it flashes, because the board is trying to tell you what is wrong with these flashes. Like perhaps bad voltage, or bad RAM or ROM? or lost all settings.
Feb 12, 2015 | HP Compaq d530 SFF PC Desktop
All LEDs are blinking/flashing. How do I fix it?
there is a service manual that indicate your problem I found 1 looking on internet, here are the instructions to know the problem in the service manual
acdce2b8-f9f0-4656-95f0-255993954bcd.jpg763fe8e3-c6b4-48f4-a00c-f806fd626ac2.jpg7b7b1adf-6167-4ff3-aaaa-bdb2b0779485.jpgb97cacda-169a-44c6-9b60-b1e02ef2e883.jpg
May 20, 2013 | Brother Hl5370dw High Speed Wireless Mono...
Error 5 with canon eos rebel 6.3 mp
there is a pin in the hot shoe that detects if an external flash is connected. check and make sure it isn't stuck down.
check to make sure the flash comes all the way up. sometimes spillage can cause the flash to not go up all the way or not to come up at all. you would have to disassemble the flash unit and clean the pivots and lubricate them with grease
If the flash comes all the way up but the camera is still 'clicking' - the lock is still moving back and forth to free the flash, then the problem is either in the flash-up switch, located on the flex on the bottom side of the top cover, is not operating properly. you would need to remove the top cover (first removing all the other covers) and repair the switch. if that switch is OK, then there may be a circuit problem. don't forget to discharge the flash capacitor - 300 volts - ouch!!!
if the flash comes up but the flash symbol keeps blinking and the flash never charges, or the symbol comes on for full flash, but when you fire it the flash doesn't fire and the symbol starts blinking again, you are probably looking at a dead flash board
Jun 02, 2012 | Cameras
My karcher 645 has three lights on the right side of the control panel. The bottom one that looks like a heater temprature warning light keep flashing when im using the machine. Is this normal or do i have...
I'm not a karcher dealer, but I'll comment. I'm assuming you've misplaced your owner's manual -- so the only way you'll know for sure is to contact karcher.com..... or a dealer.
That said, I'm pretty sure your blinking light is just bells and whistles kind of stuff. It most likely is a reminder that its time to change the diesel filter. Which means it has some "re-set" procedure. I just wouldn't worry about it.
Don
Mar 07, 2012 | Karcher Garden
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
Battery light flashes blue once, orange once. Manual says battery overheated and let it cool. Been cooling for 3 1/2 hrs unplugged from anything and still nothing. No power..and blinking blue to orange...
With battery in, boot to the BIOS, check indications under battery health. I'm pretty sure it will indicate battery decline/failure which will mean, replace the battery.
Feb 10, 2010 | Dell Inspiron 1525 Notebook
How to sync Motorola S9 Bluetooth Stereo Headset
It is pretty easy, but I wanted my instructions to be detailed, so don't panic.
Press and hold the power button for 5 to 10 seconds until it flashes back and forth between red and blue. Then go to the settings or tools section (depending on your phone) in your phone and select bluetooth and activatre bluetooth. After that select "search" to find your bluetooth headset. When you see Motorola S9 press select it and press "pair". Your phone migh task you to enter a code which will be "0000". That's all.
Jun 19, 2009 | Motorola Cell Phones
Dishwasher wont work
Press back and forth between the "sani rinse" button and the "heated dry" button several times. This should put it into a "test mode" where all of the buttons light up and the dishwasher does a self-test. Wait about 5 minutes until you're sure the test is complete, and the dishwasher will operate normally. If those 2 buttons don't work, try going back and forth between the "sani rinse" button and the "hi temp wash" button.
Jun 02, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Canon PIXMA MP150 All-In-One InkJet Printer Logo
298 people viewed this question
old marine
old marine
