Oster 5838 ExpressBake Bread Maker Logo
Anonymous Posted on Dec 13, 2008
My new Oster 5838 breadmachine: The bread pan will not come out.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jan 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
115
Points
Twist and pull hard!
Anonymous
Level 1:
  • Posted on Jan 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
115
Points
You have to twist the handle a little and oull hard! it will come out, good luck
How to set bread pan into Oster 5838 Bread maker securely
Question moved from Cars and Trucks to Oster Breadmaker.
The manual lists no funny tricks and just says;
Carefully snap the baking
pan into the breadmaker.
https://www.manualslib.com/manual/402115/Oster-5838-Expressbake-Bread-Maker.html?page=11#manual
See if you can work out what clicks? It has to be the bottom of the paddle or something on the side of the pan. Parts are available
https://www.google.com/search?q=oster+5838+breadmaker+parts
Some companies say parts are obsolete, but this site has them
https://www.dontpinchmywallet.com/sunbeam-oster-breadmaker-replacement-parts/
This image shows a spring clip in the base of the paddle. Is yours working? Are you pressing the paddle down once the pan is in the breadmaker?
https://www.amazon.ca/Oster-5838-026-Machine-Replacement-Kneading/dp/B0019BKPU4
I think I need a new pan for the Oster 5838 Bread Maker. Any ideas where to buy?
You need part number 102529-000-000, listed as backordered. Suggest contacting Oster at 1-800-334-0759, they may know when or where it is available.
The agitator turns very hard - like it is stuck partially siezed. Model 5838
Hi..The sealed bearing that the paddle shaft rotates on is starting to fail. Soon it will freeze up entirely and you will need a new bread pan. Fill the bread pan half way up with hot water a few times and see if you can free it up to "buy some time" Hank
I have a oster 5814 and set it to cook over night and found water on the floor. it leak from the bottom. Can it be fixed or should i buy a new one? My wife loves this model
The sealed bearing in the bottom of the bread pan is broken and leaking. You don't need a new machine, but you will need a new bread pan. Hank
2helpful
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
3helpful
2answers
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
1helpful
Oster 5838 and a good banana nut bread recipe
CookingCindy 1 Solution July 23, 2009 I have made the following recipe in my West Bend machine with great results. I just got a Sunbeam 5895 at a garage sale - it works great - just wanted a different "shape" loaf! I'm going to use this recipe in my Sunbeam - don't see why it won't work! Here's the recipe! 1/2 cup softened butter, cut into small pieces for good blending 1 cup mashed ripe banana (personal note: if my ripe bananas don't measure up to 1 cup, I add enough milk to make it 1 cup. Seems to be okay) 2 eggs, large, slightly beaten 1/2 cup chopped nuts (optional) 2 cups all purpose flour 3/4 cup sugar 1 teaspoon baking powder 1/2 teaspoon baking soda 1/2 teaspoon salt Grease inside of pan and knead bar generously with vegetable shortening (I just spray with Pan Spray). All all ingredients in order listed above to pan. Lock pan into bread machine. Program for quick bread. After a few minutes of mixing, I usually take a rubber spatula and scrape down the sides and stir in any flour that has not been completely mixed. I didn't do this once and ended up with a loaf that had flour coated corners! Good Luck! Enjoy! Just follow the above recipe but if your using the Oster 5838 expressbake put the setting at expressbake 80min. It works flawlessly, also with the oster 5838 expressbake you don't need to use the rubber spatula to mix after a minute because it blends everything together nicely. Thanks bobert.
Oster 5838 breadmaker
Yes. I have tried several mixes & all have come out just great. The box usually has instructions on the order to put your ingredients in (so follow that). Yeast first, then mix, then liquids on top. I've even set mine up for delayed baking & they came out well too. Good luck!
I need to fix the rool of the pan Oster 5838 Bread machine
http://minneapolis.craigslist.org/hsh/574471930.html
Try this link, ther is a bread maker for sale used exellent shape.
Also try www.oster.com and contact customer service.
Top Oster Kitchen Appliances - Others Experts
John
John
Sean Wright
Sean Wright
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
