Question about Dell Latitude D600 Notebook
The cursor doesn't respond to commands given using mousepad.
I can't make the cursor navigate to where i want it to go-
and when i take my hand off of the onboard mousepad, the cursor goes wherever it wants to go on the screen.
  • iamuseless Feb 07, 2009
    I have a Dell Inspiron 4100. I can't make the cursor navigate to where I want it to go. When I use the onboard mousepad and select where I want to go, the cursor goes/moves to wherever it wants to go on the screen. My mousepad can't grat the cursor or control it's movement. There seems to be a pulling effect on the cursor to either the top right corner of the screen or the bottom left. Can someone help?
  • 461 Answers
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Posted on Dec 14, 2008
TI-84 Silver Edition blank screen with cursor in top left hand corner blinking. Keys not responding
The command line is full. Use the left arrow key to clear the command line. Then erase all previous entries, or reset the RAM
Sep 07, 2014 | Texas Instruments TI-84 Plus Silver...
When typing, cursor jumps backward several spaces
Sounds like your mousepad is ghosting. This means it thinks you're tapping the mousepad as you type, which will make it type exactly where you nlast moved the curser to. First, try cleaning the pad thoroughly with a damp tissue, and dry it well... if that doesn't solve it, you could try adjusting the mousepad sensitivity controls on the control panel. Hope that helps.
Oct 10, 2012 | Acer Aspire 5733Z-4633
Laptop mousepad doesn't work correctly
If it is a new Laptop then I'll not suggest you to open it for cleaning because you'll void the warranty period. You can check for the latest touch pad driver and update it once. it may help you.
Aug 13, 2012 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Mousepad does not respond and cursor does not move
your system hangs! may be you have installed any hazardous one thing,reinstall the OS
Apr 02, 2012 | Toshiba Satellite L650-BT2N23 Notebook
Cursor stuck
If the mouse cursor is stuck, try looking for the mousepad toggle. Most models of notbooks have one or two ways to toggle the mousepad off. They are generally either a button right above the mousepad or a function key.
Look for a button that has two icons that appear to be mousepads, one with a line through it. If you press it (You might have to hold the Fn key located in the lower left corner if it is a function key), it should toggle the mouse back on if it was disabled in this manner.
If this doesn't fix the issue, try pressing the windows key to see if it pulls up the start menu. If so, try navigating to restart to see if that fixes the problem.
Lastly you can also try navigating to the device manager to see if the mouse drivers are missing etc. To do that press the windows key, navigate over to computer and press the alternate menu (directly left of the right Ctrl key) and choose properties. Use the tab key to navigate to the hardware / device manager tab. Once there look for the mouse driver.
If that doesn't help please post your laptop model, version of windows and any other relevant information you can think of.
Please leave feedback if this was helpful. Thanks.
Mar 21, 2011 | Computers & Internet
What does the light indicate above the mouse pad on my HP Mini Netbook? It is red and after I start up the cursor does not respond to commands.
I am niot familiar with this particular model, but based on what i have seen with other HPs, that means your mousepad is locked, similar to the hold function on an ipod.
Feb 02, 2011 | HP Mini 1000 Netbook
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Aug 18, 2009 | Televison & Video
My cursor jumps when i am writting a text
The keyboard is built in a way so that it is easy to accidentally tap the mousepad while you are typing. This will make your cursor jump., if you are using an external mouse, make sure to turn off the mousepad to avoid this issue by holding Fn and pushing the F7 button.
Mar 22, 2009 | Acer Aspire 5050-3242 Notebook
Computer not responding
I used to have the same problem... Have you got any e.g customization packs installed, because if you have then theres a chance you will need to uninstall that.
Reply back if it still doesnt work.
Jul 09, 2008 | Sony VAIO FRV37 Notebook
I have heard that there is an upgrade to the Magellan Maestro 4040, where you can actually speak to the device and get things like directions to the closest resturant. How do I get this upgrade if...
Upgrade your Magellan Maestro with hands-free Voice Command & Control for the easiest, most satisfying navigation experience.
Your Maestro 4040 will respond to your voice commands to give you quick information and an instant route to nearby points of interest. Activate Voice Command & Control and find the nearest coffee, food, gas and ATM simply by speaking. Ask for your current location and distance to destination and hear the details as you keep your hands on the wheel and your eyes on the road. Just say the word and get instant information about the nearest roadside assistance.
Purchase the upgrade and you will be given a unique unlock code. Enter the code* into your Magellan Maestro 4040 and let your voice put you in command
Apr 16, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Dell Latitude D600 Notebook Logo
240 people viewed this question
Alun Cox
