Question about Hitachi 42HDT52 42 in. Plasma HDTV
Hitachi 42" plasma TV (42PD6600)
When i connect my TV to my HD cable receiver with the HDMI lead i only get sound, no picture. The cable box has been changed 3 times so i can only conclude there is a problem with the TV. The cable reciever and the TV have been set up correctly by the cable company. The tv does work with the composite connections. How do i fix the problem or acertain where the problem is. Hit
  • Steven Shapira Feb 17, 2008
    I have a mitsubishi 73" rear projection I just bought and an Onkyo surround receiver. I cannot get the picture to work with the HDMI cable, I get sound though. I Have checked out that the receiver can work this way with another TV. I connect Cable box to in1 and TV to HDMI out on receiver. I sometimes get an error message from the TV that states "HDMI switching through AV receiver is not supported."
    I can sometimes "trick" the TV into working correctly, but when I turn the TV off and back on it won't work again. The TV is brand new so I see no reason for this not working with HDMI, and I know the receiver works correctly. Is there any way to "fix" this problem?
  • dazzlingdee May 16, 2008
    I was watching TV tonight and the picture went and I can change channels and get sound but I cannot get any picture. What could the problem be.
    Problem Solver:
  • 5 Answers
I am not sure what your problem might be, I have figured out mine though and this is a good answer for a lot of people in the future.
My problem was that my receiver is HDMI 1.3 compatable, however the newer Mitsubishi TV was 1.3a for HDMI. There is no way around this even though I was able to trick my old receiver and TV into connecting, whenever I turned it off the problem came back. I just bought an Onkyo SR805 which is 1.3a version of HDMI, and the TV receiver combo work fine now.
You might have to read your manuals carefully to make sure they are exactly using the same specs. Also, I bought a $30. HDMI cable, and I got the same picture as one that cost $120.00. It is more being the right version than who made the cable.
Posted on Feb 19, 2008
My plasma TV seems to have problems with picture immediately after turning on. At about two weeks ago, the TV lost picture after turning on the TV. It was corrected by disconnecting power then reconnecting. A switch on rear left hand side would click bringing picture ON, somehow this clicking seems to have problems being energized lately not allowing picture to come on the TV. Checked power cable and was getting 120 Volts to TV, nonetheless problem has gotten worst and TV does not show a picture? Your thoughts on my problem?
Posted on Feb 17, 2008
    Genius:
  • 1,074 Answers
IF you are saying that every thing is connected properly check your video cable it could be bad use a new one if that does not rectify your problem it is time to call in the tech you could be having problem in your video circuit but you did not mention if the screen light up with no picture but with sound or it does not light up blank with sound.however there could be two things 1 if the screen lightup with normal sound it could be a leaky ,open, or shorted, transistor or ic in the IF circuit.2 If the screen does not light up and has normal sound it could be a defective horizontal stage.so it is time you take the set to a tech for repairs.good luck.
Posted on Mar 26, 2007
How do i get the hdmi working
HDMI start by putting one end of the HDMI cable in the HDMI socket on the tv, then the other end in the HDMI socket on the device your are going to use. It can be a decoder, an apple tv or something else that needs an HDMI connection to the tv to work.
Secondly find the remote control and push the input button then there should be a picture on the screen with different possibilities for input. Click where it says HDMI.
You should be connected now,
kolbrub
May 25, 2014 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
Hi,i have a humax hdr freesat box connected to ext-6 via hdmi cable.every thing works fine on bbc1 hd,but on the other hd channels, all i get is a green screen.any ideas please?
have you used a satellite finder for maximum signal and searched the internet for the angle at which you need to align your satellite dish?
Dec 26, 2010 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
How to get the TV to start up using AUX 6 (HDMI)
menu 1325 hotel menu then select what channel to start on
Oct 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
My Hitchai plasma tv (42pd6600) has died. Can I
Try unpluging it for fifteen minutes or so, and plug it back in. Sometime a surge or guide information will make go off.
Oct 10, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
CONNECTING HDI BOX TO TV
hello, here is a link to a web sight were you can buy the hdmi to dvi converter http://www.hdtvsupply.com/hdtodvico1.html
Mar 30, 2009 | Televison & Video
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Hitachi 42HDT52 42 in. Plasma HDTV Logo
373 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
