Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 I usually turn the tv on with a remote. This time I turned tv off with power button. When I tried to turn it on again, the power would not go on. I tried both the remote and the power button on the tv. I notice when I try to turn it on, the red power light on the tv will stay on momentarily, then will rapidly blink. There were no other problems before this happend.
    Genius:
  • 1,074 Answers
Take your tv to a tech it needs repair.if you are not a tech you wont be able to do it your self.the tv is having problem in the power supply and other related circuit.good luck.
Posted on Apr 03, 2007
SOURCE:
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Need to set my one for all remote to a Toshiba TV?
Try the following codes: Toshiba 0060, 0154, 0156, 1265 . Turn on the TV manually and then press the TV button on the remote. Press and hold Set until the LED blinks twice; then release the button. Enter the four digit code. The LED should blink twice again. Test if the TV turns off by pressing Power once. If it does, check if the other features of the remote control the TV. If it doesn't, try a different code. You can also manually search for a code by pressing 9-9-1 after holding and releasing Set. Then alternate between pressing Power and TV (for a TV code). Lock in the code when the TV turns off by pressing Set. Check if the remote works for other features.
You can get the manual and codes for the One For All remotes here: http://www.oneforall.com/support/manual .
If your remote is older than your TV, you may need a new remote. Universal remotes are usually limited to codes for devices released 6 months or more before the remote was programmed.
I hope this helps.
Mar 15, 2011 | One For All URC4220 Remote Control
I have an antsig AP593 universal remote, i need the code for a toshiba television.
I'm not sure if any of the codes work! But if you want to try the codes again. Put your remote right in front of the point where your TV receives signal (i.e. where you see a light). I used method B - manual searching of the code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), about 1mm away kinda thing! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jan 02, 2011 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
May 27, 2008 | Toshiba 27A34 27" TV
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
