Question about Linksys Wireless-G WRT54G Router
Cant connect 2 laptops through linsky wrt54g is this possible
Want to hookup second laptop but dont have any luck tell me how please mike
  • 41 Answers
Are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Posted on Dec 14, 2008
Need to find out password on a wrt54g. we cant find the orrigional disc or cisco on our computers.
If you can afford to loose your configuration, find the reset button and keep it pressed while the router is on by about 10 seconds. The default login is blank and the pasword 'admin'.
May 18, 2010 | Linksys Wireless-G WRT54G Router
Dont have internet connection on my laptop
First change your LAN ip range on WRT54g, leave the wan interface as dynamic IP client. Connect your WAN port to the DSL router interface. ping your DSL router interface (most probably your DSL router will be having Make sure that your laptop is not assigned with any static IP (Incase you use the laptop in home n work).
Jun 12, 2009 | Linksys Wireless-G WRT54G Router
My xbox360 live dosent connect!!!
contact ur router company do u have a linsky router ?
Mar 14, 2009 | Microsoft Live Communicator for Xbox
Using my linskys router
If you have internet through a cellphone, it doesn't sound like the router can help you-- it's meant to split up a wired broadband connection like cable internet or DSL internet from your home phone lines. the router certainly was built to let you share a broadbank net connection-- you didnt mention if you have one or not-- not a cellphone connection... you might have to spring for another card if you need to stick with just the cellphone connection.
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
My linksys router won't allo me to connect to the internet.
Well to be honest. The reason you keep having the problem is because your router resets itself every few hours. If your routers firmware was already updated by LInskys support and the same thing happens then you will indeed need a new router. Newer models and even the one that you have are all reliable the only problem in your case is most likely wear and tear. You have had it for a few years now hence most likely its degraded to a point that it resets itself which causes your problems so yes i would suggest you get a new one. YOu can get the latest WRT54G V8
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Login on to linsky
Under this condition you should connect the linksys router physically by LAN cable and that try to get connected with and reconfigure it properly as per your requirement. If still unable to solve the problem than kindly reset the unit to factory default by pressing the reset button.and that try to get connected with and reconfigure it properly as per your requirement.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
WRT54G Router Hookup
All you need to do is connect the modem to the router. From the router, you will want a computer connected to it so you can configure your wireless network.
May 28, 2008 | Linksys Wireless-G WRT54G Router
Dsconnection problem on linksys wrt54g
I will assume that the nat table is rebuilding.
May 04, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
214 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
