Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 50 in
I usually turn the tv on with a remote. This time I turned tv off with power button. When I tried to turn it on again, the power would not go on. I tried both the remote and the power button on the tv. I notice when I try to turn it on, the red power light on the tv will stay on momentarily, then will rapidly blink. There were no other problems before this happend.
  • 1070 Answers
SOURCE: Toshiba 50A60
take your tv to a tech it needs repair.if you are not a tech you wont be able to do it your self.the tv is having problem in the power supply and other related circuit.good luck.
Posted on Apr 03, 2007
0 characters
1 Points
I have a Toshiba 63hm116 TV and I think the power button on the TV just went out, how do i fix it?
Try bypassing the power button by jumpering across the two terminals. If the set doesn't turn on, it's not the power button, it's something more serious. If it does turn on, just replace the power button with any momentary switch.
Jul 20, 2014 | Toshiba Projection Televisions
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Projection Televisions
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 50A60
Apr 03, 2007 | Toshiba 50A60 50" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
