Question about Sanyo DS27820 27" TV
Horizontal lines from dvd player on tv
I have a dvd karaoke player and when i set it up i get horizontal lines going up and down how can i fix this this tv is not like the old tv's when you had a dial. i still get a picture just not good from lines
    Genius:
  • 1,074 Answers
Connect the dvd to another tv if it gives the same problem,change the video connecting wires.
Posted on Mar 25, 2007
SOURCE:
Hod do I factory reset my karaoke player
CAVS USA User Forum - H...
cavsusa.com/kb/index.php?action=sitemap&letter=H&lang=en
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
CAVS USA User Forum - W...
cavsusa.com/kb/index.php?action=sitemap&letter=W&lang=en
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ...
www.fixya.com > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
Acesonic DGX-109 USB Multi-Format Karaoke Player with ...
Dec 06, 2015 | Televison & Video
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
My tv/ dvd player has appeared with a green line down the screen
There are two problems occurs on your TV, one is the line down the screen because of faulty horizontal deflection or faulty horizontal yoke winding. 2nd is...color of the screen are not balanced, check the RGB transistors in CRT board circuit.
Aug 05, 2014 | Prima Televison & Video
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jan 28, 2009 | Sharp 13VT-K100 13 in. Combo
How do i set my pc to connect to tv for karaoke i have nvidia
you need a male to male VGA lead to connect your laptop to a tv, make sure that the tv supports pc first, if not most DVD players supports karaoke
hope this helps
regards
Nov 18, 2008 | Computers & Internet
Horizontal rolling solution need more info
rolling in the sense? what you mean?
Feb 08, 2008 | Koss KS3161 System
GO VIDEO GVP7811 PORT.DVD PLAYER
I am looking for code to program a GO VIDEO remote to a RCA TV. The only thing on the remote is (GO VIDEO DVD video 00058E)
Nov 26, 2007 | Televison & Video
Words "roll" on Screen
sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your player must be mATCh with your tv monitor ...TRY TO set it using remote control of your dvd player...and try diff color system setting....post the result.ty eg:NTSC PAL =THESE ARE THE COLOR SYSTEM SECAM
Feb 22, 2007 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sanyo DS27820 27" TV Logo
281 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
