Question about Toshiba Tecra M9-S5512X 14.1" Widescreen Laptop PC Notebook
Power doesn't turn on
There was some liquid spilled on my laptop and I'm trying to open the casing to dry it out, but can't figure out all of the points to open it.
Can you help?
Acer laptop doesn't power up after water spill
As I'm sure you are now aware , electronics and water do not mix. That said, Remove ALL power IMMEDIATELY if you get water in /on a laptop. If the power is removed , battery, AC, you can try and dry out the spill, otherwise the damage is done. How much damage I can't say, only a qualified computer tech can ascertain that.
Nov 22, 2012 | Acer Aspire 3502WLCi Notebook
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
Hi I split milk tea on my vaio, when i was cleaning it the system close all program the shut down. when i try to run again the power led keep flashing but the system does not come up. Currently I put my...
Send it for servicing. The liquid may have seeped into the motherboard and spoilt something.
If you still want to try, but it near a warm, not hot heat source. It may speed up the evaporating of the persisting liquid in the laptop.
Jun 21, 2011 | Computers & Internet
Soda spill on inspiron
Okay shut it down, do not try to boot it up!! You want to first open the lid as far as it goes and turn it upside down to try and get as much of the liquid out. Then you want to remove the keyboard and all covers from underneath the laptop use compressed air to dry the laptop as much as you can, then with some alcohol and small brush clean soda residue let sit and dry for at least a couple of days. Then re install battery, keyboard and all covers. Then try to boot it up. Hopefully you did not short out the motherboard, or mouse pad and keyboard. Good luck.
Mar 10, 2011 | Dell Inspiron 1525 Notebook
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
What if i have spill beer on my dell inspiro lattop
Not good to do... ANY liquid splilt onto a computer can cause severe damage to it. If this happens, unplug the computer, remove the battery inspect the components extensively, making sure to dry everything off and let it air out before you try to power it up again. liquid can collect in places you can not see , so you MUST be vigilant about drying it out.
Regards..
May 20, 2010 | Intel Motherboard
Spilled coffee on D600 notebook, power supply turns off when plugged in after had the notebook cleaned. is my notebook not fixable?
When the power supply turns off when plugged into the laptop it is indicating that there is a short. Remove your battery and try connecting the power adapter again. If the problem persists your motherboard will most likely need to be replaced.
There are companies out there that will repair motherboards however if the laptop was on when the spill occurred there is little to know chance that the motherboard is repairable.
Mar 16, 2010 | Dell Latitude D600 Notebook
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
Nothing happens when I press the power button except the light
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Oct 03, 2008 | IBM ThinkPad T60 Notebook
Toshiba Tecra M9-S5512X 14.1" Widescreen Laptop PC Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
