Question about Acer Computers & Internet
I have an ACER notebook Aspire 4920 and, I think, because an update I installed (prompted I may add by my laptop!) it is now not working. When I turn it on it goes into Startup Repair mode and then tells me it can't fix the problem automatically. It then gives me the options to either: System Restore (not actually an option as when I go on it it tells me I can't do this!), Windows Complete PC restore (which i can't do as have no Backup), Windows Memory restore, or command prompt. Please help as I really need it working again by monday and don't want to lose my documents!
  • 1 more comment
  • ctrevien Dec 13, 2008
    Don't know how to do that! Argh!
    I don't have the option of opening my laptop into safe mode! Is there something I can type into the command prompt to do that? the update was something already on my computer, in the control panel actually, sitting there as an update.
    I tried the F8 trick to put into safe mode but it still brings me unto the same page of startup repair...! I guess I'm just going to have to give up and bring it to a repair shop....
    Guru:
  • 859 Answers
If you can indeed boot into a command prompt, type "help" without the quotes and you have a list of all commands you can run from the command console.
I would run this command before anything else:
CHKDSK
You may be familiar with this. To see the options you have type:
CHKDSK /?
You will want to run an integrity scan on your hard drive's boot partition usually c: . What goes wrong with XP very often is a corruption of Security Descriptors. I won't go into what they are and their role is but, CHKDSK /R will repair corrupted descriptor files and this may be all you need.
At this point you may be fixed. Lets hope so. If not proceed further with the instructions below. Be patient and prepared for a long haul.
Reboot to the command console again and see if running commands to repair your Master Boot Record and repair your Boot file are all that is needed.
The commands all start with FIX.
This includes (I'm typing from memory, use the help command for exact command) fixboot and fixmbr.
Run both of these commands.
(The commands you can run from a bootup repair console are very different from what you will see if you access the Run Box in Windows and type command, hit enter and then have a command window. If you type help here, you won't see the same commands as when you boot to a repair console.)
So, if your problem there is still unresolved, run this routine below.
You should know, that we pros do this all the time and we barely think about it or how long it will take, we just know in advance it can be very frustrating, but it is solveable. So, in this respect, don't leave us. If you want more personal attention Customer like you have used the Ask Me button to engage an expert in a more one on one session. Just be prepared for the long haul, it may be needed.
Again, if these suggestions below still do not resolve your problem there is hope. But, it will require some work on your part.
If you do not have a copy of the Windows Install CD (and your maker should send you one on your request. This is the law.)
Your install directory should be on the hard drive in a directory
Either,
c:\windows\i386
or
c:\winnt\i386
To access these files you need to use the change directory command. It is "CD and/or CHDIR", no quotes
So, CD Windows , will take you to the Windows root directory. If that fails you windows directory is probably winnt so type in
CD WINNT
Once you are in the Windows directory you need to get into the 'i386 directory, type:
CD I386 [that's an i in front of 386]
Your machine is likely tobe setup to do an unattended installation. The file you want to access is one of these depending on your make and version of XP
These are for a FAT32 system
I386/WINNT32.MSI
I386/WINNT32.EXE
For an NTFS System
I386/WINNT.EXE
Yours is probably NTFS.
You will find out when you start the process.
What you want, is to start an installation session, that's all, let the script run until you get the Stop Screen that Alerts you to the fact that there is already a Windows System installed. Here, you are offered two options. One is Repair, the other is fresh or new installation. Choose 'Repair' This repair routine is very good at resolving problems.
Now, should all this fail you, you will want to get a copy of Hiren's Boot Disk 9.1 or greater. When you bootup with this CD in your system and the CD drive is listed before your hard drive in the boot order, you will be prompted to bootup Hiren's or Windows. Choose Hirens Boot CD of course. Once this loads, you will have several options of programs that can restore partitions.
Choose Recovery Tools
There are several offered and each has its own benefits.
If you end up at this point and you have a copy of Hiren's post back and let us know, I or another will instruct you on what programs you will want to use.
Many prefer one partition repair tool over another, mostly it is a personal comfort zone thing and so on. What you want to do with these tools is recover, that is fix, your boot partition. These tools on this CD can do this for you.
Posted on Dec 13, 2008
  • 275 Answers
Try using Safe mode to restar your laptop and she if it lets you restore on this mode, usually when it doesen't let you restore the normal way it's because of a virus on your system, but if you use safe mode it will restore even if it has viruses.
  • 6,487 Answers
Try to check if you can boot from Safe mode and uninstall the update or do a system restore if it wont boot from safe mode try booting on Last known good configuration, if also failed you need a recovery cd or a windows CD to recover those missing file system.....
  • Mark Gil
    Mark Gil Dec 13, 2008
    If that's the case you really need a recovery disk or windows installation to recover those missing files or taking it to the computer repair center will be a best option for now...
  • 837 Answers
Are you saying you cannot get into safe mode?
  • Jay Glendenning
    Jay Glendenning Dec 13, 2008
    So while it is booting up if you keep tapping the F8 key you don't get a windows startup menu??
    Master:
  • 479 Answers
The update which u installed can also be a virus running into the system.try opening the pc in safe mode.and then check out.also if major problem comes u can format the pc load the anti virus software and the start loading the required files and folder and then continue.
  • tech gurus Dec 13, 2008
    go on pressing f8 when you start your computer.it will automatically go into safe mode.just continuous press F8
  • Acer Master
  • 4,806 Answers
Hi there
It seems you are in big trouble, there is no way you can recover the system now without a complete system restore, you probably do have the option because you may have a hidden recovery partition to allow a recovery, NOTE: this will wipe all data from the hard drive!!!
If you need the data from the the hard drive you must connect it to another PC as a slave device, then you will be able to recover your documents and data.
kind regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Dec 13, 2008
    hi again
    There is nothing you can do, you cannot perform a system restore or do anything at the moment unless you want to loose your data!!
    This is coming from a PC technician and i have come accross this problem many times
  • Lee Hodgson
    you don't have to take it to a repair shop at all, remove the hard drive and connect it to another computer.
    The repair shop will charge you a fortune for data recovery and system recovery
  • Lee Hodgson
    are you in the UK?
I have an acer 4920 laptop. The problem with this is that my chat mate can not hear my voice during video call or even voice call. I just want to know how to fix this problem. Please help me....Thanks in...
you might not have installed drivers for the mic on your notebook. Make sure you have installed all drivers and then go to CONTROL PANEL, AUDIO, and check if your mic is working.
Dec 20, 2010 | Acer Aspire 4720 Notebook
Heloo.. i just formatted my aspire 4920 laptop.. All of the driver successfully installed but as for the audio part it shows hd audio failed to installed. I've try to reinstalled but then same problem...
G'day,
Check this link & then click Notebook under the Select product family, then Aspire, then Aspire 4920 or Aspire 4920G which ever support your Sound driver.
http://support.acer.com/drivers_download.aspx
If it's useful for you please leave positive feedback.
Thanks
May 18, 2010 | Computers & Internet
Need to reset Acer Aspire 4920 how do ido it
how reset master bios password for notebook aspire 4920???.........
Sep 19, 2009 | Acer Computers & Internet
Acer Aspire 5738 laptop Finger not working on VISTA
It is Better do this : Instead of Updating the drivers, roll back the driver first and unintall the Hardware Totally from your system through the device manager. Next, restart your system, and then it prompts for 'New Hardware Found', use the Finger Printer Driver That you have, to re-install it afresh, if you dont have you can download it from here :
http://www.getpcmemory.com/drivers/download-acer-aspire-5738-5738g-5738z-notebook-windows-xp-drivers/
After that, restart your system again. It should work like that now.
Jul 09, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Media Touch Buttons not working for Aspire 4920
Try to re-install the Acer media touch and update your machine's bios to its latest version. (you can download it from the acer site --> www.acer.com/support)
Jul 01, 2009 | Computers & Internet
Webcam cant work
you can try updating driver for web camera and try to use in safemode and check , if it works in safemode it could be an issue with some virus and firewall settings
Jun 29, 2009 | Acer Aspire 4720 Notebook
How do I install windows vista on acer 4920
hi,
here is one helpfull link but remember backup your important data from your system before going in for reinstall
http://vistahomepremium.windowsreinstall.com/upgrade/upgradetovista.htm
if this method doesn't work let me know
Further queries are welcome
Feb 19, 2009 | Acer Aspire 5050-3242 Notebook
Touchpad scroller stopped working on my Acer Aspire 4920
Go to control panel and look for touchpad icon. You can change the settings in here. If there is no touchpad icon try the mouse icon as sometimes there is a touchpad settings tab in there. Hope this helps.
Dec 02, 2008 | HP Compaq Evo Notebook N1015v
Problem with Acer Aspire 4920 notebook
all laptops are supplied with a pre installed copy of windows and the product key will be on a genuine windows sticker on the back, unless you have no sticker, in which case you will need to purchase a copy, as nobody is likely to be able to help if you have no product key and no Vista disc
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
