Question about Motorola Mobility RAZR V3
Blue tooth My blue tooth only stays on for 60 seconds then shuts off. How do I keep it on? Please help
    Brigadier General:
  • 7,752 Answers
60seconds is only for the search mode other than that it stays on
Posted on Dec 26, 2008
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 | iPhone Apps
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
How do you reset the device?
first you must put the blue tooth device in pairing mode,most blue tooth device manufactures use the power button for this ,by holding the power button down for 6 to 10 seconds when turning the device on it usually puts it into discovery mode,a solid light might stay on ,then you have to enter a pairing or pin code.Now most manufactures of blue tooth devices use a 4 digit factory pin pairing code they are asw follows 0000,.1234,9999,or 1111 i hope this helps
Feb 26, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Samsung Spex 210 phone is telling bluetooth not found. Can you help?
Have You Put The Blue Tooth In Find Mode?
This Can Be Done By Holding The Button On The Blue Tooth Until It Flash's Red And Blue Or Stays Solid.
If This Doesn't Help Please Provide The Model Number Of The Blue Tooth.
Sincerely,
Michael Scott
Jan 30, 2009 | Radio Communications
Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Oct 31, 2008 | Motorola Mobility MING A1200
Blue tooth connectivete problem
Amii hello,
I would try shutting the phone off.
Then, remove the battery for a few seconds. Put everything back on, and turn on the device.
This is a known bug with many SE phones.
IF possible, I would also try to update your firmware.
Oct 29, 2008 | Sony Ericsson K800i Cellular Phone
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
Motorola Mobility RAZR V3 Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
