Question about Ovens
Westinghouse 476 oven wont light
Oven wont light , put in new thermal valve but still wont light. could the ignighter be the problem? it glows when switched on, are there any gas filters that could be blocked restricting gas flow.
  • 17 Answers
SOURCE: The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Posted on Jul 21, 2009
  • 1015 Answers
SOURCE: viking gas stove operators manual
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Posted on Oct 11, 2009
SOURCE: Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Posted on Jan 12, 2010
SOURCE: Westinghouse oven GWH 476 SLP
Hi RMSINN,
Believe it or not, the clock has to be set before the oven will light.
To set the clock, instead of using function names for buttons, we'll just call them buttons 1 through 6 going from left to right.
Push buttons 1 and 2 at the same time. You're now in clock setting mode. Push buttons 5 and 6 to make the clock go minus and plus.
Cheers
SG
Posted on Dec 25, 2010
SOURCE: cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Posted on Jul 10, 2011
Gas oven won't light; broiler will light; igniter glows
YOUR BOTTOM IGNIGHTER IS BAD EVEN THOUGH IT GLOWS IT ISN'T GETTING HOT ENOUGH TO SEND THE RIGHT SIGNAL TO THE GAS VALVE TO OPEN THIS IS A COMMON PROBLEM WITH ELECTRIC OVENS
MINE ALSOwww.a-1appliance.com TRY THIS SITE AND YOU CAN GET AN IDEAL OF WHAT ONE MAY COST
Feb 06, 2011 | Ovens
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Oven does not light
first check the igniter to see the color of it. if it is orange you need to replace it because it is too weak to ignite. it needs to glow white hot. second, the burning smell could be from the coil, check the coils as well near the gas valve.
Nov 08, 2009 | Ovens
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
Oct 11, 2009 | Viking Ovens
Cant reset clock on westinghouse 476 underbench gas oven
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
Cannot turn on Oven
your oven needs a new ignitor it has to draw 3 amps or more to open the gas valve (just because it glows doesnt mean its good) let me know how you make out
Feb 21, 2008 | Ovens
Ovens Logo
255 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
