Question about RCA D52W23 52" HDTV CRT TV
No audio on rca hdtv
TV was working fine. Power went off while I was not at home and now there is no volume. Good picture. I went to set up and tried no help. not on mute tried that. Is there a way to maybe reset tv or speakers?
  • RCA Master
  • 5,568 Answers
The audio in your set is probably mostly contained in a single larger IC, possibly attached to a heat sink. These often have 80% of the audio circuitry and are not immune to failure. To locate and test this area, one should have some electronic skills and at least a multimeter. If you feel you have done what is necessary to turn on the audio, you may need an expert.
Posted on Dec 23, 2008
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
No sound from tv
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 29, 2010 | AOC Envision L32W461 32 in. LCD HDTV
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
T.V. went off during thunder strom- now nothing(no audio/vedio only clicking.
IN WICH STATE ARE YOU? IF YOU ARE IN MD-DC-VA WE CAN GO THERE AND TRY TO FIX IT
CAYPIANAN@YAHOO.COM
Oct 22, 2008 | RCA Scenium M50WH187 50" HDTV
TROUBLESHOOTING VOLUME ON PROJECTION HDTV , RCA
did you go in to you menu and set you audio setting.
Feb 15, 2008 | RCA 32F531T 32" TV
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
RCA D52W23 52" HDTV CRT TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
