Question about Linksys (WIFIDESKTOP) Wireless Adapter
How do i locate my security passphrase - Linksys (WIFIDESKTOP) Wireless Adapter
  • Linksys Master
  • 4,338 Answers
Step 1:
Access the router’s web-based setup page. Open a browser and type in ( on a Linksys router) and login (default password is admin)
Step 2:
When the router’s web-based, setup page appears, click Wireless and select Wireless Security.There you should see your encryption security key or paraphrase.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 13, 2008
What is a wpa2 passphrase
WPA2 is the security encryption algorithm used by most wireless routers. It provides security for an individual's wireless network by requiring a passphrase to allow a user to connect to the network. The passphrase is established by the person who sets up the router. This person, or someone else who knows the passphrase, must provide it to anyone wishing to connect to the wireless network.
Sep 05, 2014 | Computers & Internet
Locating ssid and security password
This article from the Lexmark website will help you obtain your SSID and security information from your router.- How to Check the SSID and the Wireless Network's Security Passphrase on Your Access Point or Router
I hope this helps.
Jan 31, 2012 | Lexmark Prospect Pro205 Wireless...
Security lock has vanished, how do I make my system secure again?
you will need to browse to the following location on internet explorer or another browser.
the default login/pass is
  • Username = admin
  • Password = password
  • or pass = 1234
  1. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  2. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Mar 27, 2011 | NetGear WGR614 Wireless Router
I have forgotten my security key for connecting to the internet with my netgear wireless router
Log in to your NETGEAR router by browsing to or Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
hope this helps
Nov 11, 2010 | NetGear Wireless router EN Fast EN
My wireless does not work in every room in my home? It will not connect when I'm in my bedroom. If I try to connect it asks for a passphrase or security?
Depending on the location of the router, the home's construction and other variables - it is very likely that you will not be able to connect from every room. You could purchase an upgraded antenna that will increase your range - look for antennas that are compatible with your particular router.
You're being asked for a security / passphrase in some rooms because you're probably connecting to a neighbor's secured wireless router. Without the proper credentials, you won't get in.
You could install an Access Point, or other wireless device if the extended range antennas don't work well enough for you, to provide coverage where you want it. You might also try relocating the router to a location in the middle of the furthest points you want to get access.
Please rate this reply - good luck!
Aug 26, 2010 | Linksys Wireless-G Broadband Router
Whats the passphrase for 2wire269?
the passphrase of your 2wire if still not yet personalized it, it is the number in a bracket just below the serial number. it always has 10 numbers
Jun 29, 2010 | 2wire 2700HG-B Router (2700HGB)
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
Passphrase problem
To locate the passphrase or key you will have to log in to the web based settings page of the router. To do this you will have to be "wired" to the router and type into the address bar of an internet explorer window-
This should prompt you to enter a username and password to log into the settings page of the router. The username and password should be admin. Once settings are opened the passphrase will be located under wireless security or just under the wireless tab. Let me know if this helps.
Good Luck
Jul 03, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Procedure to secure wep
Routers can be secured in two common manners.
First the network access as you have started using WEP which I will discuss more later.
Second by assigning an administrator password. This prevents anyone except a person possessing the password from configuring your router. This is good to do however if you forget the password resetting the router will clear all of your configuration -- so keep notes to reconfigure your router in a secure place before assigning this password.
Now as to WEP encryption -- first it is preferred your network name (SSID) be unique in your area hopefully you have already changed that. Second WEP generally requires the entry of a passphrase that causes the generation of 4 keys and in a separate box the selection of one of those 4 keys as active. Wireless adapters I have seen either accept a passphrase and active key number like the router or they require the specific active key value from the router. Keys contain hex values characters 0-9 and A-F and are not identical to the alphanumeric passphrase that was entered. Entering the appropriate value into the adapter is required for successful connection.
Security is achieved on the network not by entering the "password" every time you connect to the network but by storing the passphrase (password) and/or the generated by-products in both the computer and router in advance. Since no unauthorized persons know the passphrase or password the access on the wireless is secured. Changing the passphrase periodically is not a bad idea to maintain the security of the network (must be changed in both the router and the device with a wireless adapter. Loss of a computer means loss of the control of the passphrase and should result in a change of the passphrase too.
If you have any additional questions please respond to this with an additional comment.
Dec 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Linksys (WIFIDESKTOP) Wireless Adapter Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
