Question about Ariens 34 In. Zoom Series Riding Mower
Arien524 when clutch is engaged the wheels donot pull right away
When clutch is engaged the wheels engage slowely and in the lower gears I have almost nothing.Also It seems like it does not have the power of my old 505 and only throws snow about half as far?
  • Mark Tripp
    Mark Tripp May 11, 2010
    You might want to check the friction wheel to see if it is either worn down and needs adjusting or if it needs replacing.It could very well be just an adjusting. The friction wheel is located inside the panel under the engine. When looking inside the panel and you pull on the handle to engage the wheels you will see the round disc pull towards the friction wheel if it doesn't pull in tight enough you will have problems.Also check the belt and the idler pulley for the drive make sure the idler pulley moves easy and that it puts enough tension on the belt.
    Scholar:
  • 76 Answers
Sorry I should have posted this as a solution.
Posted on Jan 14, 2009
REPLACED CLUTCH ON ZR 550 CLUTCH ENGAGES , BUT WHEN FULLY RELEASED BIKE JUDDERS THEN STALLS OUT . TRY TO ADJUST & GEARS WONT ENGAGE .
So if you raise the revs to say about 4000 rpm and let the clutch out does it stall or judder or both will it engage at all and pull away ?
Mar 07, 2015 | Motorcycles
Fiat Uno Mia 1999 Model. Replaced Clutch Kit but gear only engages when the clutch pedal is almost completely released, right at the top?! What could be the problem and how do I fix it?
It is possible that the throw out fingers have gone behind the throw out bearing housing causing the lever to be in the wrong position. If you can get an inspection plate off under the fly wheel you may see if this is the case . If not you may have to pull the box again
Jan 06, 2015 | Fiat Cars & Trucks
1st and 2nd gear keep jumping out of gear
You may want to make sure the clutch cable is properly adjusted. At the clutch lever on the handlebars, pull back the rubber cover over the end of the cable where it goes into the lever. You'll find a round lock wheel that you tighten to prevent the clutch cable adjustment from moving. Loosen that wheel then you can turn the clutch cable adjustment in or out to adjust the clutch engagement and take up. For those bikes, you want to adjust it so that there is a small amount of slack in the clutch lever. Look at the "crack" where the lever pivots when you pull on it. Adjust the clutch cable by turning that adjustment in or out until you have just barely enough opening to slip a nickel edge into the very outside of that "crack" when you apply very, very light pressure to the clutch lever (just enough pressure to take the slack out of the lever). Tighten the lock wheel back into place and try it now. Also, make sure you are using a good, FIRM foot pressure to engage each gear. If you don't engage firmly enough or the adjustment is out, then it will pop out of gear. You notice it more on the lower gears because the lower gears allow the engine to send more torque thru the clutch, thereby providing more force to make it pop out of gear.
If this doesn't help, then take it to a shop to see if it's simple worn clutch disks (easy to replace on this bike) or if the gears have worn teeth in the transmission.
Nov 05, 2013 | 1999 Yamaha V Star 1100 Custom
1987 saab 9000 turbo transmission
bad pressure plate or stuck throw out bearing.
Jun 06, 2012 | Saab 9000 Cars & Trucks
Clutch not engaging
Does the clutch not engage( ie it slips & wont pull away) or does it not dis-engage (ie always in gear)
Was the clutch dismantled or disturbed when top-end was replaced
Is clutch hydraulic or not
Jan 31, 2012 | 2005 Suzuki RM 85
I own a 2007 Harly Davidson Street Glide with the motor running n I am in 1st or 2nd gear I let off the gass I get a noise n when I engage the clutch the noise goes away
I'm not sure what you mean by "engage the clutch". If you mean when you pull the clutch lever, the noise goes away, I'd check the tension on my final drive belt. If the belt is loose, when the engine tries to slow the motorcycle down, the final drive belt tries to rise up off of the front belt pulley making it rub the underside of the starter to inner primary housing. When you pull the clutch lever in, you disengage the engine from the transmission and the engine breaking force is removed from the front pulley and the belt goes back down on the pulley.
Good Luck
Steve
Feb 21, 2011 | 2008 Harley Davidson FLHX Street Glide
I don't know how to put my 1993 jeep wrangler into four wheel drive
To engage the four wheel drive, while rolling, pull the lever back one notch and that will engage the transfer case. You can easily do that up to speeds as high as 35mph. Pulling the lever all the way back will put it into 4 low which is not often used and may grind if it does not engage right away. That really doesn't matter much because that gear is only used for pulling heavy loads at low speeds. (I use mine about once every two years) If you do need to use it, generally you can engage it with the engine off without problems. The neutral position is used to disengage the wheels if the vehicle needs to be towed. If it fails to disengage, often backing up about twenty feet or so will help.
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
Gear box goin in to gear but still like it is in nutural
If you select a gear without pulling clutch in it will grind and stall.
If you are certain the bike is engaging a gear and still seems it is in neutral, your clutch drive is broken.
Alternatively, the gear selecter fork bolts maybe loose behind the sidecover, allowing selector to partially engage only and return to neutral. Try selection thru' higher gears, place bike on a stand and turn back wheel in gear, if gears turn and motor doesn't...it is the clutch. If you cannot select a gear proper with rear wheel turning, your selecter is suspect.
Goodluck, and Cheers.
May 07, 2010 | 2004 Yamaha DT 125 R
Ford focus slow at take off
clutch slipping change the clutch
Jun 10, 2009 | 2002 Ford SVT Focus
1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
May 12, 2009 | 1998 Dodge Dakota
Ariens 34 In. Zoom Series Riding Mower Logo
239 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
