Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
Igniter on gas stove will not turn off - Jenn-Air 30 in. CCG2423 Gas Cooktop
  • Anonymous Mar 12, 2009
    We have had the same problem since ours was new and have been unable to find anyone that can fix it. Recently an appliance repair person told me we need a new ignitor module, costing close to $400.00. A new cooktop is starting to look good. It wil not be a Jenn Air product!
2 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Posted on Nov 05, 2007
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
Pilotless ignition
its the safety solenoid. thinks the gas is on, they have them fitted so if the gas is flowing and don't heat the switch it will keep sparking till it does. you will need a gas engineer to sort this out. as there is seals that if you dont put back on right you cancause a gas leak.
Oct 28, 2013 | Cooktops
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
May 27, 2009 | Cooktops
Auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Nov 17, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
Sep 16, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Stove top [gas] JENNAIR
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
430 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
