Question about HP Computers & Internet
My new dell does note recognize the HP DVD 1070i drive I just installed?
    Master:
  • 461 Answers
Did you connect the data and power cables inside the PC? Also check the jumper settings, if any, on the drive are set to CD (cable select). Does the drive open when pressing the eject button. Does the drive appear in Device Manager?
Posted on Dec 14, 2008
Hp dvd 1040 wont be recognize my PC..Someone help me!
Power on computer and enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Aug 25, 2012 | Dell Dimension 2400 (24006YYVP31) PC...
Just installed new HP dvd1270i. PC boots but
Check your power connector to the DVD Rom and also check the cables (Sata or IDE). If this doesn't bring any solution, scan your system using updated anti virus. Good luck.
Apr 07, 2010 | Dell DVD-ROM for Dimension (6t903)...
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
INstalled hp dvd1270i in my dell 4700. I have power but it doesn't recognize the drive. Does it matter if the old drive was a ribbon cable and the new one is sata?
Do you have the DVD daisy chained to the motherboard with another drive? I have the same Dell and I have 2 hard drives IDE, and a DVD with a CD burner which are seperate so they are on the other IDE connection daisy chained. The IDE controller will allow 2 devices and there are 2 IDE controllers on the motherboard. eMail me at izzoaf@yahoo.com with more info and questions and I"ll try to help.
Sep 17, 2009 | Dell Dimension 4700 PC Desktop
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Installed new dvd drive installation disk not recognized
I need alot more info than this to solve. Like model,year,kind of drive(ide or sata),operating system & any other relevant info.
Jul 14, 2009 | HP Computers & Internet
CD/DVD drive doesn't work
try removing the drive from the laptop, then go into the device menu and delete the drive. Restart. Shutdown again and insert the drive, restart - it should show a "new device" recognized. If it doesn't, the drive may just have failed. I've had it happen to a dell drive - it just doesn't see the drive at all.
Jun 05, 2009 | Dell Inspiron™ E1505 PC Notebook
HP CD/DVD optical drive is not recognized
I found that there was a firmware conflict caused by the installation of iTUNES. I uninstalled and cleared the upper and lower filters in the registry and the internal DVD-Rom is recognized. First I cleared the registry and the drive was recognized after a hard boot. So Far no twitches. Knock on wood.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
