Question about Gigabyte GA-8S655FX-L Motherboard
Pc sometimes cannot find ide devices
I have a Gigabyte 8s655fx v1.1 its been running without problems for at least a year, suddenly it cannot find my starup drives or ide device. I have updated all the drivers but it can work all day then I switch off and switch on later and no ide drives found. If I persist and reboot 6 or 7 times it will work but again and until I switch on after being off for a while can u help??
    President:
  • 2,961 Answers
You can try wiping the cmos settings, as they may be corrupt, find the JBAT1 terminal on your mobo and put jumper across pins 2-3 then back to pins 1-2. Boot up pc and reset time, date and get the bios to auto identify drives, normally F12 depending on mobo. Also check that your cmos battery isn't low as it may keep losing the settings.
Posted on Mar 12, 2007
How do you connect IDE device to GA-Z87X-UD4H
This particular motherboard does not provide IDE connections for external devices. The safest option would be to use an IDE expansion card that will plug into the PCI bus and provide normal IDE connections for your devices.
A quick search to google for "ide expansion card" will provide many good results.
May 11, 2014 | Gigabyte GA-Z87X-UD4H rev. 1.0 Socket H3...
Tempremental bootups
check the jumper settings on all the ide devices and be sure are correct. Also check cables and connections to be ok. u may also try another memory module as a faulty one could also cause failed boot
Sep 24, 2009 | Intel Motherboard
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Apr 03, 2009 | Asrock P4VM8 Motherboard
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
IDE controller not working properly
having done these things get in touch and we will go from there
Nov 01, 2008 | Intel D101GGC Motherboard
Gigabyte 8S648FX-RZ Motherboard has problems running multiple IDE devices
Ok, you have 2 x UDMA ATA 133/100/66 Bus Master IDE ports on that motherboard, so you can support 4 ide devices. It is important that you split your devices between the 2 available ide channels (each channel has a seperate ribbon cable). For example if you have 1 hard drive and 1 cd drive you'd want to place each on a seperate channel. If you have 2 hard drives and 1 cd drive it's best to place each hard drive on a seperate channel and the cd drive on the same channel as one of the hard drives. You have to make sure the jumper settings on the drives are correct (1 master and 1 slave) when placing 2 drives on the same channel for example. Most likely your jumper settings are not correct and are causing this problem. The jumpers are located on the rear of the drive near where the power cable is plugged into the drive. Most hard drives have the jumper setting printed on the hard drive. Once the jumpers are correct you should be ok.
May 03, 2008 | Computers & Internet
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all Gigabyte GA-8S655FX-L Motherboard Questions
Gigabyte GA-8S655FX-L Motherboard Logo
61 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
