Question about Olympus EVOLT E-500 Digital Camera
Olympus E500 card error
I've been using a 1 GB Lexar Compact Flash card. I took out the card to use in a reader and print since I maxed out the card with pictures I had left on the camera. Now when I reinsert the card it says "card error" and won't let me format the card or anything. I even bought a new one - thinking perhaps the old one was damaged - but still nothing but the "card error" message.
The pictures are still on the old 1 GB card, I've loaded them onto my computer without problem.
Help
  • 3 more comments
  • mydayscount Dec 17, 2008
    I have tried two CF and one xD cards and all show the same error. One of the CF cards is brand new.
  • KTHamilton Dec 31, 2008
    used my card in the computer card reader, reinserted it in camera and now have card error.
    Tried resetting as instructed . . . still card error. Have only had the camera since May 08
    How do I know if the 'pins' are damaged?
  • Anonymous Apr 14, 2009
    We are having the same problems ... down loaded pictures. Put card back in and card error so went and bought a differnt card (the other size that fits) and still get card error???
  • Barbara Fruth Eller May 25, 2009
    I took the cf card and put it in reader at work. I have done this several times with no problems. I put it back in the camera and now I have dual card error messages for xd and cf cards. They work fine in my brothers e-500 and my computer but not my camera. HELP!!
  • mydayscount May 11, 2010
    Neither the CF cards nor the xD cards work. They all show the same error. I don't think it's probably the pins in both slots. Any other ideas?
I had the same problem. Unfortunately it turned out tha I had somehow bent some of the pin. Look inside to see if some of the pins are not alingned. Then try to bend it back. I bent them back and one got a little messed up resulting in faulty reading of the images. Black flashing parts on the image. Mikes camera said the pins would have to be replaced at $200. I'm not happy as I only used my camera once. Hope you have better luck
Posted on Jan 25, 2009
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the pins in the cf slot.. should be two even rows and straight... probably needs repair
Posted on Dec 18, 2008
Picking my camera up tommorow its been repaired, it was bent and broken pins which produced the problems you are describing , including replacing cf card for xd wont solve the problem
Posted on Nov 09, 2009
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
Try
http://www.apple.com/macbook-pro/
You most likely will need a different card to be compatible with your MacBook pro. Apple website should be helpful.
Jan 20, 2014 | Lexar Electronics - Others
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Shot with Lexar Professional 233x 16 GB compact flash but can't retrieve images.
Connect compact flash to a Windows box. Check Disk with Repair and Fix.
Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
Oct 24, 2012 | Lexar Electronics - Others
Promaster Digital card reader error
These are very cheap just replace it with one from eBay. They cost less than $5 USD
May 02, 2017 | Promaster USB 2.0 Pocket Card Reader for...
In embroidery mode I insert a card adapter into my machine and all I get is a "communication error" I have a Dynex card reader which works fine on my computer. I also have PQ1 compactFlash adapter that...
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
Jun 24, 2009 | Janome Memory Craft 9500 Computerized...
Copy pic. from cd to card reader
just insert you compact flash card into your card reader and let windows to show under my computer.when you see your flash card under my computer ,enter into your cd and select the pictures files you want to copy to the flash card.Now right click you will see a pop up box ,select sendto > ,now under sendto option you will see your flash drive,just select it and your files will get copy to flash drive.
if you are unable to perform these steps just select the photo files and right click ,then select copy.Now goto your flash drive ,double click on it to open it.Now right click and select paste........that's it. your files will get copy to flash drive.
Apr 24, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Reading 4Gb Compact Flash
download the pictures from the camera direct using the appopriate USB cable, you should have no problem then..
I had exactly the same issue, with my freinds camera, turned out that my card reader just didn't like the card, I got an external reader and that worked fine.
Oct 22, 2007 | Electronics - Others
Compact Flash
Read the Manual about the Max Card size
Oct 04, 2007 | Nikon Coolpix 4600 Digital Camera
"card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Olympus EVOLT E-500 Digital Camera
E100 Memory
I just bought a 1GB compact flash card and I was really amazed how fast they are. Lexar has them with 80x speed.
Sep 11, 2005 | Olympus Camedia E-100RS Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
1,852 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
