Question about ASK Proxima DP6860 Plus Multimedia Projector
Proxima dp6860 has vertical red lines on image
I bought a used Proxima dp6860 that has vertical red lines on the projected image and redness around white parts of images. It is mounted to the ceiling. Worked great for a day or two then started doing this. Does it immediately when it comes on. What could cause this?
3 Suggested Answers
SOURCE:
projdoc
  • 2239 Answers
SOURCE: i have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Posted on Nov 24, 2009
Basti
  • 1447 Answers
SOURCE: multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Posted on Mar 26, 2010
How do i flip the image on a proxima 6860...the image is upside down.
it's been a long time since I worked on one of these,but if you select the menu and look thru the settings, you should see "ceiling" with a checked box next to it. just uncheck the box.
Aug 07, 2010 | ASK Proxima DP6860 Plus Multimedia...
Multiple reddish pink vertical lines going from
take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
May 14, 2010 | ASK Proxima DP6860 Plus Multimedia...
Can the bulb out of Proxima DP6860 work in a DP6850?
No they will not interchange.
The DP6860 takes a bulb number LAMP-030 and is a 250 watt bulb.
The DP6850 takes a bulb number LAMP-017 and is a 190 watt bulb.
If you could physically make them fit by some means, likely just the wattage difference would cause problems with the projector. These bulbs require much more electronics to light up than what a normal household bulb does. I'm assuming the projector would think the lamp is either burned out or worst case cause damage to the power supply in the projector.
Mar 30, 2010 | ASK Proxima DP6860 Plus Multimedia...
Hi
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
I have a proxima dp6860 color shadow
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
ASK Proxima DP6860 Plus Multimedia Projector Logo
32 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
polytek
Steven Wander
Steven Wander
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
