Bosch classixx 1200 blown fuse & now won't spin
Good evening I have the above washer & was happily washing away when the washer blew the fuse (in the fuse box). Now I cannot get it to spin. All help would be greatly appreciated. I really cannot afford a new one so close to christmas and am fairly handy- even for a girl.
Seasons greetings
Yvonne
  • yvonne193 Dec 13, 2008
    Thanks, Yes I tripped the switch & tried to spin the machine. It makes all the draining noises but the drum doesn't move. Although now I have removed the washing the drum will move by hand. Will look at the motor in the morning as I feel I have had too many lagers to do so now. Thanks for replying
    Yvonne
  • Washing Mach... Master
  • 3,463 Answers
If you have replaced the fuse and the m/c works but does not spin, then I would suspect that the problem is with the motor.
You would have to remove the motor and check the brushes
Posted on Dec 13, 2008
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
Nov 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
