Question about Medion Computers & Internet
I cant get the laptop to connect to a wireless router. message comes up saying settings saved on this computer for the network does not match the requirements of the network. but it does not tell me how to change the settings
    Problem Solver:
  • 33 Answers
Try checking if the laptop's wireless button is switched to on. It helps a lot! On my laptop, you have to switch a button to turn the wireless on. If i don't it's impossible to get a connect.
hope this helps :)
Posted on Dec 14, 2008
My belkin has an orange color and i cant connect to my laptop because it has an red X saying the settings saved on this computer for the network do not match the requirements or the network Please help!
Hi lil_dreamer,
The Reason why you have that message is because the Network Key on the Router did not match the Network Key that you've entered on the computer to fix this you need to access your Wireless Settings Page and check the Network Key after that we will remove the same settings on the computer and add a new one.
To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can change the security type of your rotuer to WPA, WEP or you can also Disable the security. Personalize the Passphrase or Network Key so that you can easily remember it.
Now that we have the information needed lest configure your computer.
- Click on Start or Orb.
- Click on Control Panel.
- Select Network and Sharing Center.
- Click on Manage Wireless Networks on left under Task
- Remove all the Saved Networks on the list.
- Click on Add.
- Select Manually create a network profile.
- Enter the Network Name (SSID), Select the Encryption Type (WPA,WEP,WPA2), Enter you Passphrase or Network Key.
- Put a Tick or Check on Start this connection Manually.
- Click on Connect. Wait for the confirmation and it will work fine now.
Don't forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Hi - I recently set the security on my router but am having trouble connecting to wireless on my home laptop. All other devices seem to be ok (2 work laptops, IPad, Ipod) and I get a message saying that...
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Jan 04, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
The settings saved on this computer for the network do not match,
You need to remove the wireless network from your preferred networks list and reconnect to it.
1. Right click on the wireless icon (picture of a computer) on your system tray.
2. Click on Network and Sharing Center.
3. On the upper left hand side of the page , click on Manage Wireless Networks
4. Right click on you network name and click Remove/delete
5. Now reconnect to your network.
Jun 09, 2010 | Belkin Wireless-N Wireless Router with...
Settings saved do not match requirements on this computer
Go into network connections on the laptop and select the Wireless Network. Go into properties and find the TCP/IP settings and ensure that the IP address setting is set to Automatic and the DNS settings also. If you have wireless security set on the router you will have to set that up on the laptop as well.
Jun 30, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Whilst online my connection went off using my belkin 54g, and wont let me connect again as it says, 'The settings saved on this computer for the network do not match the requirements of the network'...Why...
That message means that your wireless security key has been changed to a different password. All you need to do is go to Network and Sharing Center > Manage Wireless Network, then delete all the listed wireless profiles there. Now click on Add > Add a Network that is in range of the computer > Choose your network and connect. Make sure to type in a correct network key. That should do it.
Apr 18, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Laptop doesn't work with wireless router
in the OS issue try to remove the ip address of your computer network...let the router find the ip address suitable for the network ip...
in the router issue...try to reset and reconfigure the router.it will be reset in the factory settings..all will be renewed....
there are 2 option to fix your problem..if not solve try to send message again..tnx
Dec 31, 2008 | Linksys Wireless-N WRT150N Router
Can't secure my home network
Hey, you're on the right track however, you'll just need to synchronize the settings on the computer. Follow the steps below.
1. Open the router's admin page (192.168.1.1)
2. Go to Wireless > Wireless Security
3. Security Mode: Select WPA-Personal
4. On the WPA-Shared Key or Passprase box, type your desired password. (Minimum of 8 characters.)
5. Take note of the password, click on Save Settings.
6. On your laptop, open Network and Sharing Center
7. Click on Manage Wireless Network.
8. Please remove all the listed networks
9. Click on Add > Add a Network in Range
10. Select your network and click connect.
11. Type the WPA password that you wrote down and connect.
You should all set.
Dec 02, 2008 | Linksys Computers & Internet
Cannot access the internet
try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
>network and sharing center
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
No network
The Wireless Security of the router doesn't match your laptop's wireless settings. Make sure you configure the wireless security password correctly on the laptop. If you don't know your wireless password, try these steps:
-Connect your laptop hard wired to the router.
-Open Internet Explorer and on the Address Bard type http://192.168.1.1 press enter.
-It will prompt you for username and password. By default, there's no username and on the password type admin and hit OK. If admin didn't work, type your own password for the router.
-When you get to the Setup page, click on Wireless Tab, then click the sub-tab Wireless Security.
-Look for Security Mode. If Security Mode is WPA-Personal, the Passphrase is the wireless security key that you need to enter on the laptop's wireless settings. If the Security Mode is WEP, the WEP Key 1 is your wireless security key. Connect to the wireless network and type it in. That should solve your wireless connection problem.
Sep 06, 2008 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
149 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
