Question about Linksys Wireless-G WRT54G Router
Setiing up static ip for port fowarding on a wt54g linksys router
I need to open listen port 6112
  • Harish Rajagopal May 11, 2010
    hi,
    opening a specific port is easy.but before that for what application ,you are trying to open port 6112.for pc or for other applications like a music bridge.because for opening a specific port we have to assign a static ip .
  • Linksys Master
  • 4,338 Answers
Here is a site that will help you set it up automatically:
http://www.portforward.com/networking/staticip.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 16, 2008
Can someone please help my change my NAT to open.. i have moderate now and have tried EVERYTHING. port fowarding. upnp. dmz. hardwire. update firmware. all together . all seperately all in pairs. even...
please check if the x-box is working properly with the modem provided by your internet service provider. If yes, update the firmware of your router and reset it once.
Nov 11, 2010 | Linksys WRT160N Wireless Router
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
Need to open ports 3724/6112
You need to login to the router, go to the applications and gaming tab and then enter the following information into the first two empty lines on the list of ports to forward:
WOW1 / 3724 / 3724 / Both / (your IP address) / Enable
WOW1 / 6112 / 6112 / Both / (your IP address) / Enable
Click on "Save Settings."
You'll need to make your IP address static on your PC for this to work. Since the WRT54GS doesn't allow DHCP address reservations, you'll have to do this manually in your network setup on the PC.
Reply back with your operating system version if you need help with this.
Dec 30, 2008 | Linksys Wireless-G WRT54G Router
Port Fowarding for my Logitech Webcam
Do you know how to do portforwarding in general?
Have a look at the manual - page 21. You can also find it here: ftp://ftp.linksys.com/downloads/NA/userguide/WRT310N_V10_UG_B-WEB.pdf
You should give your computer a static IP address (or enable static DHCP), otherwise the forwarding will fail if DHCP assings a different address to your computer.
Important is that you have two entries, one for port 8888 /TCP and a second one for port 8081 /Both.
If this helped, please come back and leave a comment, to help others with the same problem.
Dec 27, 2008 | Linksys Wireless-G Broadband Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
GGPO connection problem...
go to start find the program that says run type cmd
when the comand promt opens up type ipconfig/all that should show you all the stuff you need
Jun 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
121 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
