Question about Panasonic DVD-RV31 DVD Player
Plays CDs but not DVDs
Our DVD player plays CDs, but will not play DVDs. We have had the DVD player for about four years, and it has always worked great. The trouble began a few days ago. We had a movie paused. When I went to unpause it, the movie began for a second and then stopped. The DVD player has not worked since. We have tried different DVDs, but the result is the same. It tries to "read" the disc for an unusually long time. Then, the DVD player displays "no play." And the following message is displayed on the television screen: "This type of disc cannot be played. Please insert a different disc." As I said before, it still plays CDs. Thank you in advance for any help that you can give, Melisha
  • 2 more comments
  • Melisha Thomas Mar 13, 2007
    Thanks for the advice.
  • Melisha Thomas Mar 24, 2007
    Guest,
    Thanks so much for the suggestions. We did what you said, but unfortunately it did not work for us.
    Thanks again,
    Melisah
  • Anonymous Mar 26, 2014
    when I insert a disc, the player displays "reading..." on the tv but does not play. Eventually, the display says it does not play this type of disc
  • Anonymous Mar 30, 2014
    Plays Netflix perfect for while and can't play again without many long pauses and short playing time.
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
Posted on Mar 22, 2007
    Guru:
  • 104 Answers
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
Posted on Mar 13, 2007
What would cause a panasonic cp 67 dvd/cd player to play only cds. How do I adjust the reader?
It is most likely a permanent fault as CDs and DVDs require the laser to focus differently. If the unit is a few years old it will not be viable for economic repair.
Aug 22, 2014 | Televison & Video
Brand new, won't play dvds but plays cds
HELLO
I would advise you to return the unit to where you bought it from and get an exchange unit. There appears to be a laser problem here - the DVD laser is defective - that's why you can only play CD's! (:-)
Oct 13, 2009 | Curtis DVD8078
I was given a mintek dvd player model mdp-1770 it is say no disc when there a dvd in it i have tryed recalbreting it by sliding back forth four time then loading a cd but it still reads no disc
If the unit plays CDs but not DVDs, then the LED for DVDs is burned out. There are separate LEDs for CD and DVD operation.
If neither plays, there is a more fundamental problem. In any case, only factory service will correct the problem with your "white elephant".
I have exactly this model.
Oct 07, 2009 | Mintek MDP-1770 Portable DVD Player
My samsung dvd player will not play dvds, but it
Are you trying to playing recordable DVDs (DVD+R or DVD-R) ? if so, try playing original DVDs (the type you rent or buy) those are pressed DVDs - if it works, then your player does not support DVD-R or DVD+R - If you are using a computer burner that supports bitsetting you can change the booktype of a DVD+R to DVD-ROM to fool your player.
If however your player cannot play either DVD-R, DVD+R nor original DVDs and only plays CDs, then your dvd laser diode is finished - there is one for CD and one for DVD, this is rare but happens, there is nothing you can do, any repairs would be very expensive - you are better off getting a new DVD player they are very inexpensive now and any repairs will cost you multiple times a new DVD player.
Aug 25, 2009 | Samsung Televison & Video
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell Computers & Internet
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Philips DVP3020 plays CDs but not DVDs
Try running a good quality dvd cleaner. After the cleaning cycle try a known good dvd & see if it plays. Hope this helps.
Jan 22, 2009 | Philips DVP3020 DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Plays music cds but wont play DVDS
Hi ,
You should do...
1- clean to lens
2-change with new lens
3- change the spindle motor
I hope to fine it.
Dec 30, 2007 | Zenith DVP615 Portable DVD Player
try it on diff plug or open it must be sme wire has been broken
Aug 01, 2007 | Pioneer DV-444 DVD Player
Panasonic DVD-RV31 DVD Player Logo
560 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
