Question about GE Monogram® ZET1038 Single Oven
GE ZET1038 Oven Door Won't Close
My GE Monogram ZET1038 Oven door does not close all of the way.  It closes about 95%, but does not appear to have the spring to pull the door all the way closed.  The oven still works however.
  • 3 more comments
  • Anonymous Jan 03, 2009
    i have tried to adjust this oven door also but cannot.
  • Anonymous Jan 04, 2009
    Exactly the same problem, and can't find our book. Somebody please help.
  • jkgremer Jan 11, 2009
    We got the door off - here is how - open the oven door slightly approximately 2 inches and pull straight up. No screws to loosen, lock handle, etc, it comes right off.... Now what - I am going to see if there is an adjustment screw then put the door back on... Same problem, but at least we can see it a little better.
  • KCC1986 Feb 24, 2009
    I have the same problem on the equivalent doors on a double oven. We are on our fourth service call to replace the hinges. The service techs tell us that the hinges are not properly designed for the weight of the doors and as a result will not pull the door closed. My next step is to file suit against GE for a defective product.
  • pookiesf Mar 14, 2009
    I posted the original problem with my oven. There doesn't seem to be a solution to this problem. It unfortunate there is no solution. Will keep checking....
barkencoa
  • 3463 Answers
SOURCE: top oven door will not close..appears left hinge
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Posted on Dec 15, 2009
  • 641 Answers
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
Posted on Jun 05, 2006
  • 87 Answers
SOURCE: Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
Posted on Jun 10, 2007
textonor
  • 130 Answers
SOURCE: my oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Posted on Jan 06, 2008
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
Display shows door not closed for self cleaning when door is closed
think it means lock door . there might be a sliding lever between the cooktop and oven door slide it to the right .
Feb 20, 2015 | GE JKP20 Electric Single Oven
Doors do not close all the way and the problem is getting worse
the door hinges generaly cause this problem and will have to be replaced . some cn be shimed but best to replace them in sets // do not do one only. or you get to do job over . mm
Jul 15, 2010 | GE Monogram® ZET1058 Electric Double...
F1 error
Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Feb 16, 2010 | GE Monogram® ZET1038 Single Oven
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
Top oven door will not close..appears left hinge not working
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
Hello I just bought the house and my GE oven door won;t close all the way in. Could you please help?
there is a latch in the top of the door that locks in clean mode . need to get it out of clean mode
Sep 03, 2009 | GE Profile JT912 Electric Single Oven
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
GE Monogram® ZET1038 Single Oven Logo
1,327 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
