Question about Toshiba Satellite M115-S3094 Notebook
Help and support won't boot nor will system restore
I have a toshiba satellite m115 laptop. I was having internet troubles and tried the help and support link. an error popped up telling me the system service is not running, to fis it start the service named "help and support". Where is that? I also get told to restart my laptop when I try the system restore, that just keeps telling me the same thing everytime I restart it. I think it's doing that as a joke to see how many times I restart it.
My restore disk will not recover my toshiba satellite m115
Most likely, assuming your system disc is operational, you need to do a hard disk reset. The easiest way to do this is to delete any partitions that appear while doing the install, and doing a "fresh" install. This removes the partitions that are in the lower level of the hard disk drive. AKA - Low Level Format
Jan 28, 2014 | Toshiba Satellite M115-S1061 Notebook
My toshiba satellite laptop keyboard just quit and won't work, totally frozen and nothing appears as i type. pls help toshiba satellite laptop A215-S5837, windows 7, vista
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
May 12, 2011 | Toshiba Satellite A215-S5837 Notebook
I have a toshiba satellite m115-3094 laptop with no sound other than the systems sound alert beeps, it crashed and reloaded windows xp, updated all the drivers from toshiba.com and tried all of those...
click start--setting--control panel--sound and speech --speech and audio devices-- driver--update driver the recomended drivers will be automatically installed from net by auto serching
Mar 30, 2010 | Toshiba Satellite M115-S3094 Notebook
Toshiba m115-s3094 won't go past black start up screen
try pressing f8 when it starts up and selecting safe mode then click start > programs > accessories > system tools > system restore and try restoring to an a time when it did boot up ok.
If you dont even get a menu up when you press f8 then try f11 or f12 for a boot menu and select ide 0 it may be that it is trying to boot from another device
Oct 27, 2009 | Toshiba Satellite M115-S3094 Notebook
My Toshiba Satellite M115 S3094 will not boot. It
If its not booting at all then you should understand that it may be because of any of these reasons :
  • Faulty mother-board or any module of it. You will need to replair it by any technician & its a difficult & costly task.
  • Another reason is due to damaged RAM and its most probable also. In that case you can just simply replace your RAM with a new one and its not so costly also.A better RAM will enhance your system's performance too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 30, 2009 | Toshiba Satellite M115-S3094 Notebook
Well,my laptop(Toshiba Satellite M115-S1061) freezes after startup.It runs good for a couple of minutes, and freezes afterwards. And you can't do nothing after that.
it seems to be your operating system is corrupted it is done by virus try to format ur os drive nad immediately scan ur system with kaspersky antivirus this solves th problem of urs
Mar 18, 2009 | Toshiba Satellite M115-S1061 Notebook
Won't boot up
A bit more info would be good. Did it shut down normal. can you enter bois. any messages???
Dec 06, 2007 | Toshiba Satellite M115-S1061 Notebook
Toshiba Satellite M115-S3094 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
