Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Bb sized greenish lite
My tv is only 3 yrs old and this lite appeared in the middle of the screen recently.
  • mike montgomery Mar 27, 2007
    It looks just like a light green b.b. if this box was the screen itt would be here at the period.
    The period didnt stay in the middle which is where the light is, its just a bit and to the left of center.
    Genius:
  • 1,074 Answers
Where is the light vertically or horizontally and what color is the light.please specify.will be awaiting.you can contact me on this website or on my email nicodhem@yahoo.com
Posted on Mar 26, 2007
SOURCE:
White dot in the middle of the screen
you have a bad dlp chip hear a link for you so it will help you to unstay.
how the light eng http://www.youtube.com/watch?v=eyAykjZ3zs4
Dec 23, 2013 | Mitsubishi WD-52525 52" Rear Projection...
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a brand new 1day old 60inch sharp aquos led tv since we hooked it up it has had a faint greenish line going vertically right in the middle of the screen. nothing makes it go away. do you know what...
This greenish line is due to physical screen damage. This is not repairable and not your fault.
If you didn't drop this tv, then the TV was damaged in the box.
Return your TV to the store you bought it as soon as possible. The longer you wait, the more chance they'll tell you that you damaged the TV and that they're not responsible for customer's physical damage.
Mar 11, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV screen goes black, 43 lites appear and TV shuts off after 2 to 3 hrs of operation. It will restart OK however. 56" set is 4 yrs old, orig lamp in TV
If you have never replaced the lamp it is most likely to be the problem.Most lamps last 2-3 years under normal use.
Nov 22, 2009 | Samsung DLP HL-P5663W 56" TV
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Philips 109 cm rear projection TV model 43pp925
try unplugging the circuit board thats connected to the green picture tube thats the board in the middle then while the boards unplugged try to power up the tv if it works it means your green picture tube is shorted
May 25, 2008 | Televison & Video
Green blotch on screen
Took it to a dealer-the lite engine needs replacement.
Mar 12, 2008 | Hitachi Televison & Video
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
It may be that some dust is on the projection lens. It is possible to remove the screen and clean the mirror and lens. However, it could also be an issue with the light engine itself.
Mar 12, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
