Question about Sony KV-20V60 20" TV
My son has a Sony kv-20v60 tv and wont keep the volume turned down. Is there any way to make an adjustment inside the set to limit the volume, even when it's turned up to maximum?
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Sony KV-40XBR700
If the display seems normal when present, you may have what is called a 'cold solder joint,' possibly in the area of the horizontal power supply. This can be caused by normal heating and cooling of a particular spot on the circuit board that finally fractures the solder and making the joint thermally sensitive.
Most component failures, even when intermittant, would affect the display in some obvious way such as distortion, contrast, brightness, etc.
Posted on Feb 11, 2009
  • 51 Answers
SOURCE: The volume ramps to maximum. I can adjust it back
Sounds like the circuit board for the button keys in front has a shorted tactile switch causing sound to keep increasing, Replace all switches on this board or get new board. I believe it is called a HS board or very close to that.
Posted on Dec 30, 2009
1986praveenk
  • 108 Answers
SOURCE: the volume of sony wega kv-sw29m61 set always to
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Posted on Jan 16, 2010
  • 1274 Answers
SOURCE: SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Posted on Feb 17, 2010
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
Sony KV-27S65 27" Television suddenly has very low volume
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Jun 03, 2010 | Sony KV-27S65 27" TV
My volume on my sony tv wont go past 12 it will higher and lower but the maximum it will higher to is 12 have i maybe put a volume lock on it??
The only way the volume could be limited is if you were in the hidden tech menu----many of these sets have a setting there for initial volume level and maximum volume level.
Were you in the TECH menu for some reason?
I can tell you how to get in but you have to be very careful if you make any ADJUSTMENTS there--over 200 things can be adjusted there.
Let me know if I can help.
SD TECH
Feb 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dec 30, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
Jul 23, 2009 | Sony KV-20V80 20" TV
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The remote control just turn on the t.v
Does this model have the control buttons on top of the set? If so most of the time re-routing the cables inside the TV that go to that board solve the problem as high voltage static from the CRT cause issues with the micro. Or you might have one or more switches stuck or something spilled on them.
Mar 07, 2007 | Sony KV-32S26 32" TV
Tv has a mind of its own
Just had the TV repaired for the same issue. According to the shop it was a bad channel up/down switch. That impacted the other functions (menu not working, remote malfunction) because they're all intertwined. Only about a $75 fix here in the DC area, so maybe cheaper elsewhere.
Sep 02, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
