Question about Optoma RD65 65" Rear Projection HDTV
Replaced lamp, now lamp lights up but wont stay on.
I replaced the lamp in my 2004 Optoma RD65. After replacing, TV worked great, watched for approx. 15min. next morning set would not get a blu screen or picture. The lamp is actually turning on but shuts off after a few seconds. I can see the light thru the small openings. Is it the power supply? did my balast coincidently go bad after 15min into the new lamp. I purchased the lamp on line BLVU120A $165 it has a one yr warranty, but I don't think its the lamp.
4 Suggested Answers
SOURCE: No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: Lamp light on picture off
You might try unplugging the set for maybe 20 mins. to see if that might help in resetting the internals. Good luck!
Posted on May 14, 2008
  • 147 Answers
SOURCE: My tv a Optoma RD65
most likely a faulty power cord not sending enough power to the TV or the projectors, for projections, bulbs for plasma, burnt out
Posted on Mar 01, 2011
  • 5 Answers
SOURCE: Optoma RD65 Service manual
ANYBODY OUT THERE THAT WANTS TO SELL THEIR OPTOMA RD65 TO ME FOR PARTS. I NEED A COLOR WHEEL. PLEASE CALL WALT @ 313 220-5440 THANKS
Posted on Oct 26, 2011
I have a optoma rd65 when on it makes a loud humming noise
You most likely have a failing color wheel. This is a known problem in the RD65. If you search on EBay for an RD50 color wheel it is the same one that goes in the RD65. They are roughly $150 depending on who you purchase from. They can be user replaced if you are handy with tools. The bearings wear out and this causes the humming you are hearing. Optoma RD50 color wheel replacement AVS Home Theater Discussions And...
Sep 23, 2014 | Optoma RD65 65" Rear Projection HDTV
How do I get rid of the message on my tv screen after I replace the projector lamp? It is a Sony Wega KDF-55E2000?
After you replace the lamp you need to go in to the setup menu. go to the lamp replacement option and select start.
Sep 11, 2013 | Optoma RD65 65" Rear Projection HDTV
Did you ever find the service manual for your RD65. I am also looking for a service manual, Optoma will not provide the manual. This TV is out of production due to all the problems with it, you would think they would help out those of us that had faith in their product and spent our hard earned money. Optoma's Tech support and customer service is terrible. If you have the service manual I would be willing to pay for a copy. Email me at waltlevick@comcast.net
Nov 03, 2008 | Optoma RD65 65" Rear Projection HDTV
Replaced bulb stil issues
In most projection televisions if a solid light comes on there isn't anything wrong the bulb there is a problem with one of several cards in the back of the television. I'd check for over heating damage on your imput cards, the Controller card that is connected to said input card, or the relay card that controls the tube output. Keep in mind you did order a part off of Ebay which is untrustworthy in and unto its self.
Sep 01, 2008 | Optoma RD65 65" Rear Projection HDTV
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
No picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Nov 11, 2007 | Optoma RD65 65" Rear Projection HDTV
No Picture
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma RD65 65" Rear Projection HDTV Logo
24 people viewed this question
Top Optoma Televison & Video Experts
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
