160GB st3160215a shows on 40 gb on my p4vmm2 v8.1 mboard.
  • ianyoneyama Dec 13, 2008
    Sir!
    Thanks for the reply.
    Thanks for the reply, never tought anybody will be replying about my concern. Cause i dont have any ebanking knor credit card.
    heres some details might help you,
    Mother board: P4VMM2 8.1
    OS: winxp pro sp2
    HDD: 160Gb barracuda, ST3160215A
    cant find disk manager on control pannel, how ever disk management under computer management says theres no other unalocated space. so more likely this is not partition issue. and also bios says its only 40 GB on auto detect. and i tried manually configuring hard drive to meet 160gb but syill system says 40gb.
    hope you can help me with this thanks again.
    Ian
    Hey thanks, I really appreciate your concern.
    how ever been to that solution already and still the same. its already on 1.1f.
    i think its time for me to get this computer replaced.
    Thanks again.
  • 81 Answers
It might be partitioned to 40 GB.
Restart the computer, go to the setup page and look for the hard drive and check the size indicated there. If the size is 160GB, you will have to create another partition in Windows (I assuming your are using XP). Go to Control Panel - Administrative Tools.
Look for the Disk Manager and Select your Disk. It should have a 40GB primary partition and 120GB of unpartitioned space.
Just right click it and select create and extended partition.
Good luck
Posted on Dec 13, 2008
  • Marcelo Antelo Dec 13, 2008
    ok. Since the bios also says is a 40GB, the only thing I can think of, is to activate the LBA for such disk.
    Restart again, go back to the BIOS, find the disk and select it. Look for any lines that say LBA, and get sure that they are activated.
    If that does not fix it, your last chance is to update the BIOS firmware, you can get the last version and instructions from the manufacturer here
    Be careful and thorough with the firmware process, since you could kill your mobo for good.
    Please, don't forget to rate my answers!
    Sorry to hear that.
    We gave it a good try!
Seagate 160gb hard drive recognized in device manaager but not my computer why
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Aug 24, 2011 | Barracuda Networks Seagate ST3160215A...
Can I install a HH Seagate 160GB Ultra ATA 133
You can if you have an IDE connector on that motherboard.
Jul 07, 2010 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
I have ST3160215A 160 gb but it showing 137.4 please help!!!
Assuming that the jumpers at your hard drive is in the
right position. Run Scandisk to correct defect of the hard drive. If there's no change after the running Scandisk, then, the portion after the 137.4 either used space or a defective one.
Oct 13, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Replacing failed hard drive
it depend upon ur bios version
u can have hard 40 to 80 Gb
Mar 22, 2009 | Dell Latitude D600 Notebook
Seagate ST3160215A Hard Disk PCB Card Short-160 GB ATA
Hi sunny_2003,
There are many hard drive pcb supplier such as http://www.hddzone.com/seagate-pcb-c-1.html
Be sure to backup your data.
Mar 11, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Toshiba Motherboard and Harddrive
No you can't replace the ata m/board but you can upgrade your hdd's up to 160gb in ATA
Dec 08, 2008 | Computers & Internet
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
