Question about Hitachi 61UWX10B 61" Rear Projection Television
No power to Hitachi 61UWX10BA Projection TV. Have tried steps found in other blogs.
All of a sudden my TV stopped working. It worked fine yesterday and today it will not turn on. A red light on the front of the TV is present when the TV is plugged in, but neither the front power button or the remote work to turn it on. When pressing the power button I hear a faint electrical click sound and same thing when I turn it off. There are some lights illuminated on the circuit board when it is plugged in too. I have tried unplugging it from the power strip and going straight to the wall outlet without luck. I have removed the back panel and do not see any obvious blown fuses. I know nothing about TV repair so any responses should consider me the lowest common denominator. I haven't stuck my hands in there too far as I don't know what the shock risk is and am still enjoying breathing. Any help would be appreciated. If you need me to take pictures of any specific components to help with the troubleshooting, please let me know. Thank you. HOMER: "No TV, no beer make Homer something something." MARGE: "Go crazy?' HOMER: "Don't mind if I do!! Whoooaaaaablaaaoooblaaaaaaa!!!"
  • 2 more comments
  • Brian Schwind Mar 13, 2007
    Here is a picture of the board in the bottom right of the TV (looking through the opened back of TV.) The fuse looks fine, but there is some black char or melted tape in the lower right. Any idea what that is? Am I barking up the wrong tree?
    Another pic of the inside.
  • Coujon Dec 13, 2007
    I have the 61SWX12B and I'm have the same problem. The TV was repaired in the past for audio problems. I have the Hitachi service manual and I do have an electronics background. So far I found FP04 to be opened and also looks like CP15 maybe be bad as well. Could this be it? I do have the board out and before I put it back in I would like to be sure this is all that needs to be replaced. Any and all help would be appreciated.
    BTW, If anyone needs and do have the Hitachi service manual.
    Thanks,
    Dave
  • nannersdad Feb 20, 2009
    tv will not turn on getting power most leds are green but one is red can hear what sounds like sound turning on and some other clicking sounds but screen is blank
    Genius:
  • 1,153 Answers
These set are good for having convergence amps go out, and also audio problems. So if your set had experienced color alignment problems, or sound problems this may tell you what is going on. There are codes for Hitachi, and it's in the LED lights that lights up when you plug in and then hit power button. Some LED lights up and goes off some stay on this tells a tech what is wrong, I use to have code but gotten away from Hitachi, but if you could safely tell me which ones maybe I can help further. Like I said, this set has had many problems with convergence amps going out. There are small fuses on the big board that do not look like the ones in powersupply. They usually say F001 or somthing to that sort. They sometimes can be yellow in color, but the problem is replacing without fixing problem will have it going out again. So hope this helps. and Read the threads here on sets like yours becaus the answer might be here already.
Posted on Sep 21, 2007
Hi, I have the Hitachi 61UWX10BA projection tv but I tried the (input+power on)con)combination and enter in the service mode to fix colors changing the numbers, do you have the complete original numbers...
Well here is a link to Hitachi which claims to be free,but you have to register,and I have seen free stuff before and after you fill all the stuff out,they want some kind of card.So at least try this one.I am going to look for others too...just in case.
http://tv.manualsonline.com/manuals/mfg/hitachi/61uwx10ba.html
It did work.I clicked download this manual,without joining or anything,and it worked.You do need Adobe Acrobat reader.It is a free,SAFE download.I have had it a long time.Just google it (obviously) if you do not have it.No pop ups or any of that garbage.If you are not familiar with Adobe,near the top you can change the image size.Good luck!
Jul 31, 2010 | Televison & Video
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
Tv stopped turning on
often found cold joint on the coil of power relay and on transformer near of flyback.+B pin of flyback
Apr 27, 2010 | Hitachi 55FX48B 55" Rear Projection...
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10BA Convergence Still Off After Chip Replacement
Remove Front bottom Panel thier you will see front of convergence board there is a small blue contact switich with TV on press and hold it for 5 sec then you should see convergence Pattern so you can aline convergence correctly I have the whole Manual to tv just have to find it. anyway for now try this.
Dec 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
1,027 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
