Question about Dryers
Dryer will ignite and get hot briefly then go cold
Dryer will ignite and get hot for a couple of minutes, then gets cold. I completely cleaned the vents - there are no obstructions. I tried replacing the radiant sensor that attaches to the burner tube but it did not resolve the issue
  • 145 Answers
More likely problem is your gas valve coils are bad. Very common problem. As you described, burner will fire up initially and then will no fire again the rest of the cycle. Testing the coils with a meter will not help you here. The wire inside them is as thin as a human hair and they will check"good" with a meter.
FWIW, that radiant sensor rarely fails.
Posted on Dec 13, 2008
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Dryer doesn't stay hot
Probably 95% of the time this is from the gas valve coils. The part # for a kit with both coils is 279834. You can try unhooking the vent from the back of the dryer to eliminate the venting as a problem. If it runs ok without the vent hooked up that is the problem. If it still won't keep heating thru the cycle replace the valve coils.
Jun 16, 2009 | Estate TGDS840JQ Gas Dryer
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Start gas dryer heat will ignite after a couple minutes no heat
That is usually a sign that the gas solenoids are weakening. Sometimes for some dryers you can buy a pair. Don't know your complete model number.Thanks, Sea Breeze (Visit my site)
http://servicepartstec.blogspot.com/
Mar 23, 2009 | Kenmore Dryers
Dryer won't stay hot
Possible problem is the gas coils sticking. You can verify this if you turn on the dryer and are able to see the igniter glow orange and shut off without a flame in the burner funnel.
http://tclaundryrepair.com/home
Feb 19, 2009 | Whirlpool LGR5636L Gas Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
