Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Hello I just hooked up my Hannspree 19" monitor [HF199H] and continue to receive an error message: "input our of range, check video cable". What does this mean and is there anything I can do to correct it. I'm working with Windows xp operating system.
  • kmh28 Mar 21, 2009
    hannspree when I plug into the computer the display states input out of range
  • ladyxxslink Apr 07, 2009
    i get the same error message, ive had the monitor for over a year, and this just started a couple months ago. before the error message comes up, the screen is all distorted and goes black.
    Problem Solver:
  • 16 Answers
Either your settings in the display are set to high,or your trying to run high level of hertz,or the other way around
Posted on Jan 14, 2009
My monitor won't adjust horizonaly or verticaly.
If you wish to get some details; check the site linked here. Pull up older posts. ...
http://electro-medical.blogspot.com/
Jun 13, 2016 | Hannspree HF199H 19 Flat Screen LCD...
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
Out of range error
Out of range message means that the video resolution signal the monitor is receiving is not supported by the monitor. How do you hook up the DVD player to this monitor since it does not have composite ot component video inputs?
Spec: http://techwiki.hardwarecanucks.com/product/1NjEyNzUxMzgzMzE/ASUS-VW192T/#spec
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | ASUS VW192T Monitor
Monitor says: no signal input check video cable Even though the computer is on and hooked up
if it says so....it indicates that the display card is gone bad. check with the display card...
or try inserting New Graphic card or PCI VGA card... works for sure....
Jun 23, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Volumn button is not working, what should I do? Vicky
Check the speaker Icon in your systray to see if it's muted or needs to be turned up.
Feb 08, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
No sound for Hannspree HF199H 19" LCD
Kalungka,
you need a third lead to connect from your sound card line out to the line in on the monitor.
Regards
ElApe
Sep 26, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
309 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
