Question about AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381
Rewiring mootor from 230v down to 115v
I have a century pump motor, part number 8-152000-02. 2.0 hp. 3450 rpm. the motor is set on 230v and i would to change it to 115v but the wiring daigram on the cover plate is missing.
the motor is wired as:
terminals from the switch to the motor
1 white black and yellow
2 ----- -----
3 black
4 red
5 white
6 white yellow
can you help with this problem
thank you
    Scholar:
  • 121 Answers
Not amperage draw doubles from 12 amp to 24 amp. A thirty amp circuit 10 gauge wire, will need to be wired from the breaker panel. a single 35 amp. breaker will be needed. Depending on the motor a larger circuit may be needed. Using 40 amp wire (8 guage wire) and a 40 amp circuit breaker may be required.
Posted on Oct 30, 2011
    President:
  • AO Smith Master
  • 1,388 Answers
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
How to rewire my century 3hp ac motor part # 8-141443-02 from 230v to 120v
look on the side of motor it has a schematic for 110 volts and 220 volts have to move wires or turn a switch
Sep 11, 2015 | Century Pool & Spa
How do I get a wiring diagram for motor model 370200
There should be a wiring diagram under the connection cover plate that tells how to connect wires for both 115v and 230v service.
By the way, any motor of any brand with a #56 frame and 1 hp or better that runs at 3450-3600 rpm should be suitable for use on a table saw. 1.5 hp would be better. (I upgraded mine to 2hp)
Harbor freight has a suitable 1.5hp replacement motor for $140.
Depending on the motor you get, you may have to buy a pulley at the same time to match the shaft diameter and blade rpms.
Sep 25, 2014 | Saws
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I have a 1hp 3450 RPM single speed AO Smith motor on my pool pump and it just quit. My question is can I replace it with a two speed motor? If so I'm sure I will need some type of controler to change the...
Some motors have two speeds listed on the spec plate, study the wiring diagram on the plate to see if the speed is set by the way you wire it.(which leads you twist together at the motor)Good luck
Nov 22, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381 Logo
2,555 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
