Question about AOpen AOR-401M Router (90.18R10.402)
Which transformer to use
Trying to clean up a wiring mess and I have mixed up which transforer goes to what.. AOpen router AOR-401M just says DC-IN but I need to know the output required. have four adaptors all with different Voltage outputs that will fit the female input plug! 4.5 9.0 12V all with similar male plugs.
I know some of these AC Adaptors are for long gone printers, fax machines etc.
To solve the problem I tosted the whole mess of wires and equipment and bought new equipment. $8,024 spent and now all the new converters are labeled. The industry needs to mark all equipment with DC-IN 9V or whatever. This is a real problem if you have kids and grandkids and too many different standards.
Posted on Dec 16, 2008
How volt transformer for AOpen spekers?
If it is the transformer, it should be a DC output. Look where it connects, it will tell you what voltage you need. Use a volt meter to see if you are getting that from your "transformer". If so the amp in the speaker is probably blown, if not you need a new DC power supply with the correct voltage. If the replacement ma is higher that will not hurt, The information should also be on the "transformer".
May 31, 2016 | AOpen Audio Players & Recorders
Transforer has three places to hook up wires instead of two
This will be for different output voltages.
Use multimeter set to ohms to test which wires have continuity.
If you connect Hot and neutral to wrong wires, it will burn up the transformer.
Copy following lind for illustration showing Intermatic 4-wire low voltage pool transformer:
http://waterheatertimer.org/images/PX-600-wiring-diagram-900.jpg
Jun 09, 2012 | Intermatic Malibu 300W Power Pack...
Forgot WEP password -- Where can I find it?
You will either have to call you ISP (Internet Service Provider) and ask them to reset it, or you will have to stick a needle or pen into the reset button on the router to reset it all, the new default password should be the number on the back of the router.
Jun 29, 2011 | AOpen AOR-401M Router (90.18R10.402)
Aopen ms-805 s/n 10800730 RWE1 What DC Voltage
A/C Adapter Output: 120V AC 500mA UL Approved
Nov 13, 2010 | AOpen MS-805 Computer Speakers
I NEED A TRANSFORER for A WULITZER ELECTRONICS ORGAN
If you need 52 VAC I would get TWO 25 VAC transformers and series the secondaries to get the 52 VAC. The 25 volt ones are usually readily available. Sources include Digikey.com, Mouser.com, Allied, Newark.com.
You will need to have ones with at least the current rating necessary.
Sep 08, 2009 | Music
I cant find mine either
Can you briefly explain your problem.
Jul 17, 2009 | AOpen AOR-401M Router
No power to my router
Check the wall outlet for power, using a lamp or such. If you can get a multi-meter, set the meter to Volts-DC between 12 and 20. Plug the power supply into the wall outlet and test the other end for voltage. The power supply should tell you its output so the reading should be more than a couple of volts. If it is less or ZERO the power supply is dead. If it has power, then open the router and check for a fuse. If the fuse is dead, replace. If there is no fuse or the fuse is OK then the router may be dead. Best of luck.
May 29, 2009 | Linksys Wireless-G Broadband Router
Can't find WEP key for DS
You can see the WEP key at the side or bottom of your modem. Its the 10-digit code. If it is not listed there, you need to access the Setup Page of Motorola modem. Go to internet explorer and type http://192.168.1.254
Jan 20, 2009 | AOpen AOR-401M Router
Nintendo Wi-fi Connector Problem
nintendo ds should work with most routers it's just the set thats a problem, once the wifi game is in go to wifi connection one settings,then where it says auto obtain ip address click no, then edit,then use an ip address that is the next digit up from your pc or your router eg, if your routers ip address is 192.168.2.1( this is what you would type in your internet browser to get into the router settings), the next digit used by a pc would be 192.168.2.2, so use 192.168.2.3 or above incase you have more than one pc. Next is the subnet mask which should again be as the routers subnet mask which will more than likely be 255.255.255.0., press edit and enter that number Next is the gateway setting, press edit, this is the same number of your routers own ip address as mentioned earlier this is the ip address you type to get into the router eg 192.168.2.1. next is auto obtain DNS, again click no, then on the primary address click edit and again enter your routers own ip address. next is secondary DNS, again click edit and again enter your routers ip address, then click save settings. You should now be able to connect to your router and the wifi connection at nintendo server.
Jun 30, 2007 | AOpen AOR-401M Router
AOpen AOR-401M Router (90.18R10.402) Logo
63 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
