Question about Euro-Pro 8260 Mechanical Sewing Machine
Thread holder for bobbin winding hold
I have a Euro Pro 8260 sewing machine. The long plastic thread holder that is used when to transfer thread to a bobbin broke off, can it be replaced. I tried to super glue it but it did not hold. Thank you, Michelle Levick
  • Jerry Stahl
    Jerry Stahl May 11, 2010
    If you can provide a photo of the broken part and lication where it attaches to machine it would help greatly.
SOURCE: needle will not pick up bobbin threat
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Posted on Feb 22, 2008
SOURCE: Euro-Pro 7133 - Thread is getting stuck underneath
I had the exact same problem!!!!finally i took to the store and they showed me that i was not threading the too string correctly. what you have to make sure that the needle is at its highest position and that you thread it through all the guides!
Posted on Mar 07, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
SOURCE: euro pro 385w problems
if your machine is like mine the bobbin is not filling right. My bobbin thread is very loose when it should be tight. I am also looking for bobbin solutions. If I wind the thread around the thread tension guide 2 or three times it keeps the thread tight going to the bobbin winder. I hope this helps
Posted on May 31, 2009
Euro pro 9130 Bobbin holder jumps out of place when sewing, then the machine locks up, tweets and stops sewing. I have ordered a new bobbin holder and that did not help.
check the upper thread tension
make sure all the thread guides all used- & that the thread is not hanging up some where on the machine
check the top thread tension dial to see if there is any thread caught in it
change the top & bobbin thread- make sure the thread is not knoty or old
Mar 12, 2012 | Euro-Pro 9130 Sewing Machine
The thread keeps tightening and loosening causing the stitching to be off.
This happened to me once on my machine...Pfaff. There was a teeny weeny bit of thread caught in the tension disks. I slid a piece of paper between the discs and eventually got it out. Also....if you sew with cones the thread tension often goes off because cones are not meant to be used on the spool holder. Buy a special device for holding cones of thread....it sorta looks like those verticle paper towel holders. (a disk with a stick poking up from it) This will solve your tension problems and prevent needles from breaking all the time. If neither of these ideas help......maybe your machine needs servicing. Give these a try first.....might save yourself a big repair bill. If you can't find the cone holder........wind off thread from your spool onto a bobbin and use that as your upper thread.
Dec 21, 2010 | Euro-Pro 9125 Computerized Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
My bobbin isnt winding correctly
re-thread sewing machine for bobbin winding. There should be a screw looking thing that holds the thread taut while threading
May 26, 2010 | Euro-Pro Shark 60 - 384
Threading upper is not moving
Get out the manual and make sure the needle is installed correctly and the machine is threaded as the manual indicates - always with the presser foot up.
Check the bobbin to make sure the thread is feeding from the spool in the proper direction and through the correct guides.
Check the tension setting - it should be between 3 - 6 - or as recommended in the manual.
Hold onto the the thread tail at the needle and lower and raise the needle by turning the handwheel. This will pull up the bobbin thread.
Take the thread tails of both threads under the presser foot and to the back of the sewing machine before you begin to sew.
Feb 23, 2010 | Euro-Pro 8260 Mechanical Sewing Machine
Bobbin thread/feed dog eating fabric
Happy stitching,
Kim & Linnette
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Euro pro 385w problems
Jun 25, 2008 | Euro-Pro Easy Sewlution 385 Mechanical...
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Euro-Pro 8260 Mechanical Sewing Machine Logo
57 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
