Question about GE Profile Spectra JGBP90 Gas Kitchen Range
One burner does not light up. The ignition is clicking and providing sparks, and there seems to be plenty of gas. It works fine when i put a match to it.
  • 145 Answers
Make sure the burner cap or burner head is in place correctly, and that the jet or hole(s) for the ignition are clean of debris. In most cases like this, if there is spark present and no ignition, it means something is either clogged and dirty or the spark is not strong enough due to poor grounding.
Posted on Dec 13, 2008
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ... > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
ground path the spark will go there. It will
not, however, in most cases have found a
ground path such as what the fl ame would
provide under normal circumstances. This will
the spark module to re-ignite.
Sep 01, 2009 | Viking VGIC485-6G Gas Kitchen Range
Igniters won't turn on & unwanted flammes
You say you have no sparks coming from your gas range, but your rear burner is lighting. That doesn't quite make sense. If some of your burners are lighting, then the problem can't be with the spark module. The spark module sends a spark to ALL the igniters at the same time. That is, EACH burner switch, when turned to ignite, will cause a spark to go to ALL the burner igniters at the same time. Just watch the next time you turn one of your burner switches on, and you'll see a spark at all the burners simultaneously. This is normal. I suspect that you have a bad igniter switch or wiring harness. For example, if you have a front burner that won't light, but WILL light when you turn on another burner, the spark is being provided by a working burner switch. This is also normal. Now, am I assuming that your back burner will not light properly, but will light if you use the front burner? If so, the burner switch for the rear burner is probably bad, or the wiring harness has a break somewhere. Now...if you have no sparks, as you say, but randomly a burner will light, then I would suspect a bad spark module. I hope I'm not confusing you here. In a nutshell: One burner doesn't work, but all others do - bad burner switch, or wiring harness. No burners light, or light randomly - spark module. I hope this helps you.
Jul 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
98 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
