Question about Toshiba Satellite A100-S8111TD Notebook
No power the from battery adaptor to my laptop
Hi there i have a toshiba satellite pro a 100
the problem is when i connet the power adaptor to the laptop theres
no power at all no light either the power cord don t get hot i had this
problem when i first had the lap top they repair it and they said it was
the c p u could it be the same problem agian i would like to be for i order
a part
    New Friend:
  • 21 Answers
Hi, get another adaptor to confirm the problem. It could be your adaptor that is faulty.
Posted on Dec 13, 2008
Toshiba l300 power problem
Check if the adaptor is working fine. Use a multimeter to check the voltage output from the adaptor.
If the adaptor is working fine, please add a comment to the question.
Aug 27, 2014 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite will not start
yes..that's precisely what's needed..
Mar 16, 2008 | Computers & Internet
I have a Toshiba L35 Satellite S2174. I lost my power adaptor so started to use a HP adaptor of same 19 V , but Different Current 3.16A. I dont have the current rating of my original charger. The...
Hi Arsalan
To answer your question Its "yes". wrong power/ampere rating can shorten the battery life. I recommend that once you replace the battery include the AC adapter.Thanks
Feb 20, 2011 | Toshiba Satellite L35-S2174...
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
Battery won't charge
replace the power adapter, and if it still give the problem, change the batter.. if must be faulty that is why it is not charging.
May 19, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba wont charge
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
Can't get power
Hi Doc, How have you determined that the A/C adaptor is working correctly? When you plug the adaptor into the laptop do any of the LEDs do anything? What about the battery, can you run off it?
Jan 07, 2007 | Toshiba Satellite Pro 490CDT Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
