Ferroli f24b hot water intermittently goes cold whilst running.
3 Suggested Answers
SOURCE: Ferroli DOM F24B Is leaking
Yes, this is a common problem on the domi compact. unfortunately ferroli accept no responsibility if not in warranty period! can be a costly repair..
Posted on Aug 19, 2008
SOURCE: We have a FERROLI F30
did you find a solution?
Posted on Jan 07, 2011
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
How do i reseat the prv on a ferroli f24b boiler?
Hi, any pressure relief valves i have ever worked on, can't be reset. They are there to release water pressure that builds to high. If they continue to leak if you have discharged it, you can tap on it to see if you can get it to seal, or just replace it if it continues to run or drip water.
Sincerely,
Shastalaker7
Dec 30, 2010 | Heating & Cooling
Fault code f26 ferroli optimax 25c how to reset
There is a parameter on the pcb to change would take 30seconds to do. Never replace ur pcb for these faults. Hold down reset untill u see t5 press reset 1 more time it will then say p01 press the heating temp button until u see p02 press the hot water temp button until it changes to numberv2 and that will fix ur problem
Dec 25, 2010 | Heating & Cooling
Ferroli boiler 31 che will not light up when hot water switched on notice in windowe says no ca or no co
are you getting no ca or no co on the time clock? if so change the time clock
May 16, 2010 | Heating & Cooling
Why does my Ferroli HE31C keep switching off code A3.
Here you go, page 30, sounds like it's overheating, possibly a problem with the boiler stat or lack of circulation in the system. http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Apr 06, 2010 | Water Heaters
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Ferroli DOM F24B Is leaking from the two 22mm pipes on the secondary heat exchanger
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
