Question about Dell Dimension XPS 400 PC Desktop
Dell xps 400 keeps shutting off before booting up
Haven't used the computer in a while and would not turn on. Unplugged and tried to turn on and shut off within seconds
  • Milind Shetti
    Milind Shetti May 11, 2010
    How old is the system ?
    Does it have an intel or AMD chip?
    Do you know how to boot into BIOS and check system temperatures ( If the system has his function available).
    If you do not know even the basics of your system then take it to a
    technician to diagnose your problem as any advice given here will
    require you to have at least a basic understanding of how a system
    works in order for you to resolve the issue.
    Thank You.
    Novelist:
    Champion:
  • 233 Answers
Unhook each device from the power supply,
one device at a time except the mother board plug. If it stays on when any of the devices is disconnected that is the one that is causing the problem. If this doesn't give results try a known good power supply. Or if you have added a lot of devices to your unit you may need a power supply with more wattage. If none of this helps it may be a more expensive problem like a bad motherboard. Also test your memory one stick at a time. This is all I can think of right now but I may think of something else later.
Posted on Dec 25, 2008
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
I have a Dell XPS and we recently moved from LA to MS. We unplugged system and then a few weeks later when we went to set it back up in the new house all we get when we turn on the system is the following...
I suggest that you reseat the memory sticks on your desktop. Most likely one or more of the memory stick is bad. If you have more than 2 memory stick, try booting up your computer in pairs until you have isolated which memory stick is causing the problem.
Hope this helps....
Sep 11, 2011 | Dell XPS 400 PC Desktop
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 20, 2010 | Dell Dimension XPS 400 PC Desktop
My Dell XPS 400 PC will not Boot up past the "System password"
Both the system password and the BIOS password are set in the BIOS CMOS. You need to clear the CMOS.
The online Dell service manual for the XPS 400 provides a clear and detailed procedure for clearing the CMOS. It's just a matter of moving some jumpers around:
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
If you are not used to working inside computers, start with "Removing the computer cover", then go to "System Setup" and click on "Clearing Forgotten Passwords".
Another method is to unplug the power cord and remove the CMOS battery for a 1/2 hour or so. For details on how to do that, try this website:
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
May 22, 2010 | Dell XPS 400 PC Desktop
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
Computer shut on and off repeats over and over again
When you say "funny noise", you could have a hard drive failing. On Dells, if you push F12 while booting, you should get a boot menu. Diagnostics should be in that menu, it's a Dell feature. Anyway go in there and run some tests and see if it reveals anything. If the tests pass cleanly, you may just have a Windows problem.
Feb 24, 2009 | Dell XPS One Desktop
Its a Dell XPS 400
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Feb 19, 2008 | Dell Dimension XPS 400 PC Desktop
Dell Dimension XPS 400 PC Desktop Logo
135 people viewed this question
Alun Cox
