Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
ROSEY HUE ON DISPLAY SCREEN
Dear technician, The normal situation when I begin to record is to have the display screen that opens out to be CLEAR. Lately however, when I open it and start to record I notice a dominant ROSEY OR PINKISH hue and I cannot remove it. Please help me restore this screen to CLEAR. Many thanks and I do look forward to your advice. Antonini
    Novelist:
  • 154 Answers
The camcorder might have CCD chip gone bad. Only way to repair is to replace the chip by trained technician. If it is under manufacturer's warranty, send it to Sony quick for repair. See also Sony's website if this model is under CCD advisory for free repair for out of manufacturer's warrnty products.
Posted on Mar 14, 2007
Why is My screen white when I power it up and won't change?
There's nothing switching the display. the back of the screen is usually a bank of white LEDs behind a diffuser or a white florescent flat tube. That is what you are seeing. In front of this is a layer with each pixel point represented by a blue red and green LCD cell.
When current is applied the structure of the LCD becomes amorphous and the light shining from behind lights up the pixel through a polarising screen.
If you can see the white backlight then some thing may have gone drastically wrong with the display. that's unusual because normally the display is all 'off' when the display is at rest (no current). So either your display/ video output is in serious trouble or it's another issue that I can't answer because there's not enough info.
You may need to take it to a repair technician to assess the situation in person.
Mar 17, 2015 | Sony VAIO Computers & Internet
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Screen has odd green hue occasionally when turning on then flashes.
It may be a bad connection in the display adapter. Try another adapter. Beware, some after-market adapters are not wired correctly.
Aug 17, 2017 | Apple Cinema Display 23" HD Monitor
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How do you record outgoing message?
RECORD AN ANNOUNCEMENT
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Jul 02, 2009 | Lands Phones
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
Can't see when recorded.
On LCD screen do you see display on camera mode or its just blanck?
If display is present and camera picture is not seen than the electronic problem is occured in camera,may be dry or loose connection which is common ,in this situation just opening camera and cleaning connectors and assemble back will solve the proble.Or camera DC-DC converter faulty inside.
Dec 13, 2007 | Sony Handycam CCD-TRV318 Camcorder
Lc display
how many hours do you have on that monitor could be lamps or just fusses
Nov 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
