Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Bottom Freezer
The refrigator doesnt work but bottom freezer does
    Scholar:
  • 31 Answers
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
Procedure to force into defrost cycle
Posted on Jan 10, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Posted on Aug 15, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore bottom Freezer
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I CHANGED THE FILTER AND SET THE SETTINGS AND IT BEGAN TO WORK A FEW HOURS LATER THE DISPLAY WAS SHOWING ER NOW THE REFRIG. IS NOT COLD AND THE FREEZER IS NOT WORKING AND THE ICEMAKER IS NOT WORKING ALL IN...
If this is the Kenmore french door model with bottom freezer and ice and water in the door made by LG it could be that the mother board has failed.  Call for service and hope that warranty is still in effect.
May 19, 2009 | Refrigerators
Freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Mar 14, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore Elite model 73503201, Refrig hot, freezer working.
first, sears doesnt make any of their own appliances, but they do sell them, so you can be upset, but it is fixable. what is happening is the freezer fan is not running causing no cold air to circulate. the reason the door strip feels hot is it has a heater to prevent condensation and when the unit is cooling properly it will feel normal temps.
check to see if you can hear the fan running in the freezer, if it is then you may have a defrost problem, but most likely you have a bad fan motor. remove the rear panel in the freezer and check the fan to see if it is turning. if not replace the motor.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
