Question about Ovens
Glass door drip marks
Any idea how I can remove the drip marks from in behind the glass on the front of the door of my oven. I can't see an easy way to remove the glass to clean in behind.
  • Ron Coons
    Ron Coons May 11, 2010
    if you provide me the model number and manufacture of oven , ill lookup the part breakdown to further assist you.
Since the manual doesn't tell you how do this, and the repair place can't either (other than a service call) I got a little creative without trying to take the whole door apart. First, un lock the hinges and take the door off, It's a bit heavy so be careful. Lay the door on it's back. Now find something long and thin ( a yard stick will do) drench a long cloth with windex and then slide the cloth and the stick between the glass, just make sure you hang on to the cloth so you don't get it stuck between the glass. This worked perfect for me, and saved a service call. Poor design, it should be simple to remove the glass, I guess the designer never cleaned an oven. Make sure you put the door back on correctly, othewise you will go nuts. Angle it in on a 45 dregee angle to the first notch. Then instead of naturally trying to close it up, pull it down slowly to towards floor to open up the hinges and then close it back up. Good luck
Posted on Feb 14, 2009
The inside glass on the oven door just cracked and pieces of glass fell in behind. Not sure why. Can this be easily replaced?
yes but easily? maybe not to easy? removing the door can be a hassle. if u can find the glass rather cheaply it may be worth it
Mar 05, 2015 | Ovens
Dripped inside top of oven door. Need to clean the glass inside door.
you will have to remove door and the inner part of door comes apart... be careful there is more glass inside than you really can tell... lay the unit on a rug or something once you have it removed and disassemble ... fairly easy process. requires just a couple of tools and a little patience.....
Jan 05, 2011 | Ovens
Cleaner has gotten behind the front glass, how can i remove the front glass? thankyou
Here is a tip that I wrote about the oven door glass replacement...
You can use it for getting to the glass also...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 10, 2010 | Ovens
How do you clean behind glass on oven door.
you will have to remove the door from the hinge mounts. then the door has screws at the top and bottom, as well as some have screws going into the handle.
lay the door on a big flat surface, remove the screws, then seperate the front from the inside. that should give you enough access to get to the stains on the glass.
Jan 09, 2010 | Ovens
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Jul 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Food behind the glass front
upper oven will not heat after going thru cleaning cycle
Jan 18, 2008 | KitchenAid KEBC208 Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
265 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
