Question about Cambridge Soundworks C1MUSWKE CD Shelf System
CD Lid/door catch broken, will not stay closed
I have one of the MusicWorks Simple Source Audio Control Centers from Cambridge Soundworks (CSW). This system was given to me. The top load CD lid is a "soft touch" open/close. There is a small, square, spring loaded mechanism with two pincher like prongs mounted in the base. This mechanism holds a single prong from the CD player lid. The part simply pos out of the base and is not connected electrically to anything. It appears to be a lid close/hold mechanism only. I have asked CSW on how I can get one of these parts to replace mine, which is broken, and not allowing the CD door to stay closed. CSW directed me to send it to them to repair as "the part is not available". How can they repair it if the part is not available. I think it is, but need to find out what it's called and where I can find it. I'm sure the part is only a few dollars, and certainly a lot less than sending it to CSW with freight and automatic bench charges. Can anyone help?
  • 1 more comment
  • kingbutler Oct 31, 2008
    I have to struggle with the prongs to get the lid to close so I can play CDs.
  • Anonymous Dec 05, 2008
    I just picked up the center console radio / CD player with the same problem in a thrift shop. I paid $2. for it due to the lid not staying closed...(and it didn't have the amplified speakers). It appears to work except for the lid closing as previously described. I wonder if using a rubberband to keep it closed would work.... haven't had the chance to pickup the amplified subwoofer or volume control yet to test it, but it seemed to work with headphones pluged in and my hand holding down the CD lid.
  • Peter H
    Peter H Feb 15, 2018
    If anybody is searching for these small plastic latches in 2018 to replace a broken one in a portable MP3/CD player like I was; then try Aliexpress at this address https://www.aliexpress.com/item/Small-do...
Sorry to arrive so late at this party but if anyone is encountering this problem, you can replace the latch lock with a: sugatsune pr-4pk
Locks in like the original and same form factor!
Cost about $1.40
Posted on Feb 11, 2010
Chris, I know it has been a while since you posted this and I don't know if you ever solved your problem but if not....you might want to check out this sight. http://search.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes?_sop=2 Kennyblan@charter.net
Posted on Aug 21, 2007
Cambridge SoundWorks 765i does not turn on. The light on the power supply is on.
You have a power supply issue and that explains the dead silence. You might want to check the PS area for swollen or leaky caps, a common source of trouble.. Or a broken solid state device. Otherwise .................................Shopping?
Sep 03, 2017 | Cambridge Soundworks Audio Players &...
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Jan 04, 2013 | Cambridge Soundworks SWBE SoundWorks PC...
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
CD won't eject from our Cambridge Soundworks 740 system. Help.
Unplug the unit for 10 mins. Plug back in then hold the CD In button until it reads "RESET".
Mar 28, 2009 | Cambridge Soundworks CD-740 In Stock Shelf...
Hi. I cannot setup the Cambridge Soundworks DTT2500
What is the exact problem you are facing?
Thanks
Kevin
Jan 31, 2009 | Cambridge Soundworks CSW DeskTopTheater...
CD Player does not load CD
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Oct 12, 2006 | Cambridge Soundworks 740I CD Player
Cambridge Soundworks C1MUSWKE CD Shelf System Logo
3,231 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
