Question about Casio DW290 1V Classic Alarm Chronograph Sport Watch
Model & spring issue with an ol casio G-Shock when replacing batt
First, I'm not sure of my model - if the DW designation is it - mine reads DW 004. Have othe numbers but don't know if it anything to do with model - 1825 and on the back cover B288.
I took out the bad battery and notuced that a very small spring was on the table - I'm not sure where it goes and/or purpose.
Any help on either would be appreciated
  • 2,334 Answers
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Posted on Dec 17, 2008
I changed the batt. in my casio g shock dw 5600e and the screen will not light up.
you had to reset it by shorting it, it is located inside your watch. or push all the buttons at the same time. i hope i had been helped you.
Jul 21, 2011 | Casio DW-5600E-1VCT Wrist Watch
Manual for Casio G Shock DW-6900
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Sep 29, 2010 | Watches
Need user guide/manual for g shock DW 6500
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Mar 16, 2010 | Watches
Casio g shock dw-9052 how to change from military time to standard time
You can get instructions from the Casio web site which will tell you how to set your watch..
Accept terms
Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Model & spring issue with an old Casio G-Shock...
Yes, definetely thru that rubber gasket, otherwise there will be no contact and no sound respectively.
Dec 17, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Manual for casio G.shock DW-5900
How do I replace the battery on a casio wrist watch?
Apr 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
Apr 24, 2008 | Watches
Casio DW290 1V Classic Alarm Chronograph Sport Watch Logo
437 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
