Question about Brother CS-6000
Machine is telling me E6 error but there is no thread tangled
Error message E6 but I cannot see any tangled thread, and it will not let do anything. Help. Brother 6000i
  • mms_mm2 Mar 07, 2009
    I have this same problem. I keep getting the "E6" message but there is no thread tangle. It will sew perfectly fine for a second then it will lock up and say there is an error. I have no idea what to do.
I am in the middle of fixing this same error. I phoned Brother service in Manchester and they are spot on. Give them a try, they talk you through the problem and suggest things to do to narrow down the cause. Make sure you have the model and serial number as this saves time. In extreem cases you can send your machine to them by parcel post and they will look at it free of charge and then give you an estimate for any repairs needed. If you decide not to go ahead, you can elect to have the machine returned to you for the cost of the postage.
In my case I bought the machine second hand off of E-bay and was getting the dreaded tangle/needle message. I phoned the service department and I was told to thread the machine up and switch on. Then they give you several things to try. Essentially you need to get someone to press the start button while you immediately turn the handwheel forward gently and smoothly.
If this stops the message coming up then you must suspect the motor or its fuse. In my case, it would seem the machine had been dropped as there was a hairline crack in the circuit board which stopped the power getting to the motor.
Posted on Jul 30, 2009
If your thread is not tangled .The E6 will come up also if the top thread is not threaded properly. Is your thread breaking at all ?
Posted on Feb 05, 2009
    New Friend:
The same problem with mine. It's almost new, but begun to show this error. And there is no thread inside. It seems to be a software error.
Posted on Apr 25, 2013
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
Feb 02, 2018 | Brother Sewing Machines
I keep getting the e6 error message for tangled thread but when i go to fix the tangle there isnt one and both bobin and spool spin freely any help would be great im at a total loss
The "thread out" sensor can be triggered if the thread is not between the tension disks. That is usually caused because you threaded with the presser foot DOWN. You MUST raise the presser foot when you thread your machine; that is the only time that the tension disks are spread to accept thread.
May 10, 2015 | Brother SQ9000FS 80/120 Stitch & Alpha...
After 3-4 stitches, machine shuts down. On display panel E6 show up.
Error codes are on page 62 of this manual.
It says " The motor locked up because the thread is tangled.
Remove the tangled thread before continuing operetion."
I would guess that this could happen for anything that would cause too much load on the motor.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CE_5000PRW_EN_1444.PDF
Sep 24, 2014 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
I am using my Brother CS-6000i sewing machine for the first time and keep getting the E6 error code. It worked fine for the first 2 rows of stitches I did then I got the error and the thread was tangled. I...
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
Jan 09, 2011 | Brother CS-6000
Error message E6
Go to www.brother-usa.com and you can download your manual for free or call them, Your E6 message means that you have a thread tangled and you must get it out of the machine, totally unthread and brush bobbin area and feed dogs then, unplug and it will reset, then plug in and rethread,
Aug 24, 2010 | Brother CS-6000
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Brother CS-6000 Logo
1,029 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
