Question about Maytag Legacy Series Top Load Washer
How do you tighten the belt on magtag washer
Top load washer Magtag ensigina only has 1 belt already lid switch not problem I think the belt is slipping
can you help single mom need you help
  • 1 more comment
  • sunny31 Dec 13, 2008
    model # MAV6458AWW THANKS
  • sunny31 Dec 14, 2008
    MODEL MAV6458AWW thanks cant afford $92.00 for someone to come out if I can do myself
  • rcaugh676 Apr 25, 2009
    I put in a new trasmmsion now in rence it will not spin the belt seems to be very slack...
  • 706 Answers
Hello sunny31,
If you believe the belt is slipping then the belt will need to be removed and replaced. There aren't any belt tensioners in your washer.. Can you provide the specific model # with a response so I can provide you with more information on how to resolve your problem?
Regards,
Rick
Posted on Dec 13, 2008
  • Rick Gelin
    Rick Gelin Dec 14, 2008
    Hi Again,
    I understand the cost thing and you should be able to get a replacement belt for about $15 and change it yourself if you are reasonably handy or you have friends that are.. Here is a link with pictures and parts lists for your washer http://www.pcappliancerepair.com/model-d...
    Item #30 is the belt.. Hope that helps you...
    Let me know if I can help you any more.
    Regards,
    Rick
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
HAVING AN ERROR CODE (OP) ON MY WASHER TOP LOAD MAGTAG NEPTUNE, WHAT SHOULD I DO?
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
I discuss the troubleshooting the Left Hand Lid Lock in that sticky.
I can't find my repair notes on this forum no Sticky and no Service Manual.......D*ick
Feb 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Trying to put belt back on magtag sav2655aww. do
Maybe this breakdown250 will help, not sure, hope so.
Nov 11, 2009 | Maytag SAV5710 Top Load Washer
How do I clean water filter on a magtag top washer model LA613T
You may have a screen in the inlet side of your fill hoses. There is also a screen just inside the valve. Turn off the hot and colt water shut off valves. Start a cycle on warm wash to be sure both shut off valves are completely closed, and to relieve the pressure within the hose. Remove both hoses at both ends. If there is a screen in the hose connection...remove them, clean them and carefully reinstall them. The screens in the washer valve will be just inside the valve where the hose connected. Carefully remove, clean and reinstall them. Connect hoses back to washer and shut off valves using care not to cross thread. This will damage the connections and require replacement of the valve. Do not over tighten. Once all connections are secure, turn the water back on slowly and check for leaks. If you are uncomfortable doing this repair, it is a very inexpensive repair when a tech does it for you. Watch him or her do it, and do it yourself next time.
Oct 23, 2009 | Maytag Neptune MAH6500A Front Load Washer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain
look for blockage in hoses and pump.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Magtag Legacy series top loader washer
replacve your watervalve hot side celionoid is stuck shut must replace valve
Apr 08, 2009 | Maytag Legacy Series Top Load Washer
Agatator problem
being a maytag about 30 years old i would say the belt is broke or transmission is locked up ,,,, if it was a newer style you may have difference problem that could be easier repaired
Dec 08, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
MAGTAG STACK WASHER
The 1E error codes relates to a lid lock failure. You should replace the lid lock switch. Good luck!
Nov 21, 2006 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
354 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
