Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Adobe premier elements 7 won't load into my computer
Install error...computer does not meet min sys requirements...requires a CPU that supports SSE2 instruction set... is there a solution short of getting a new computer?
If I am going to need a new computer what features should I be looking for...cost is a concern...One of the things I want to od is edit family VHS to DVD. I have been using Photoshop elements 3 to edit still photographs and am upgrading to Elements 7... Thanks, hope you can help.
respond to dunfordgg@msn.com
Sorry so late I have been away. Yes that error message is tell you that you processor does not have the feature you need. Now you could check to see if you can upgrade your processor but if you are looking to get into video editing it might be a good idea to look for another computer. I'm not a video gurru but I will tell you what I do know, you proccessing power is a necessity and you HD space is also an necessary. Your ram shouldn't be no less that 2gigs; I would go for 4gigs myself. Your video card is a must 512 or higher and I would go with Invidia, good Gforce card if you can afford it go with the video rendering cards where you can put to together, a little more costly but it's great performance.
That's all the info I have on this, oh do a Dell XPS, or a hmm... I would do Dell.
Posted on Jan 10, 2009
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
ERROR READS SOFTWARE MODE SSE2
(Single Instruction, Multiple Data) processor supplementary instruction sets first introduced by Intel Seems to me that the software your loading requires this to run it. You may not be able to support it. Check out other questions and answers. Your processor more than likely does not support the software your installing. John
Apr 13, 2012 | HP Pavilion A230n PC Desktop
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
Trying to load elements of CS3 and get error ERROR ''NEED SUPPORT FOR CPU EXTENSION SSE2''
Unfortunately, there isn't much you can do about this. Your processor is quite old, and as a result doesn't come with SSE2 built in, which is an instruction set that helps the CPU process data at a faster rate.
Your only option is to purchase a CPU that has SSE2 built in for you to be able to use that program.
Hope I clarified things
Nov 25, 2009 | Zerus Athlon XP 2000+ , 1.67 GHz...
Use CPUID (CPU-Z) so you'll know the specification of your cpu. This will include all the instruction set of your cpu.
Here's the website
http://www.cpuid.com/cpuz.php
Jun 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Changing a cpu on a compaq 5000T/REM
I've located this description when installing the pentium 4 processor on Windows XP. If you have not performed these steps this may be the cause of what you are experiencing. To save you time I've pasted the section below--> Operating System Support
Nearly all modern operating systems designed for the Intel Architecture have support for the Pentium 4 processor, although some may require specific versions or processor support files. Many Microsoft operating systems like Windows* 98 SE, Windows NT* 4 with Service Pack 5, Windows* 2000, Windows* ME, and Windows* XP support the Pentium 4 processor. Linux* distributions based on the Linux* 2.4 core support the processor. Also, many other vendors have support for the Pentium 4 Processor in their operating systems. System integrators should verify that the operating system they have selected supports the Pentium 4 processor.
Note: Windows XP or certain versions of Linux are required for Hyper-Threading Technology2 support for the Pentium 4 processor. For additional information on integrating systems based on the Pentium 4 processor supporting Hyper-Threading Technology, refer to the Integration Overview for Systems Based on the Intel Pentium 4 Processor Supporting Hyper-Threading Technology.
All operating systems that support the SSE instructions that were first introduced with the Intel® Pentium III processor will also support the SSE2 instructions introduced with the Pentium 4 processor. To experience the power of the SSE2 instructions, it is critical that system integrators install drivers and software that have been optimized for the Pentium 4 processor's SSE2 instructions. For example, for maximum system performance, system integrators using Microsoft operating systems that support DirectX* should load DirectX 8 (or higher).
Software Optimization
With specific drivers that use the SSE2 instructions, graphics accelerators, audio hardware and software, and other system resources can experience substantial performance gain. It is critical that systems also use APIs that use SSE2 instructions to achieve maximum performance. Two examples are Microsoft's DirectX 8 (or higher) and Open GL 1.2 (or higher). Most major graphics accelerator vendors have optimized drivers that use the SSE2 instructions. Graphics card vendors typically highlight support changes with new driver releases. Download and install the latest drivers (dated later than October 2000) from the vendor's Web site. Also, verify that the driver version contains optimization for the Pentium 4 processor.
Many applications also use the SSE2 instructions to experience the breakthrough performance of the Pentium 4 processor. System integrators should contact software vendors to verify support and determine version information.
System performance is greatly affected by proper operating system and driver installation processes. For example, it is important to install the latest Intel® Chipset Software Installation Utility immediately after installing most Microsoft operating systems to ensure proper drivers for the chipset are installed prior to installation of other drivers. System integrators should confirm boxed Intel Pentium 4 processor-based systems are optimally configured and integrated.
Conclusion
Boxed Intel Pentium 4 processor-based systems require proper integration. System integrators that follow the guidelines in this document will experience higher customer satisfaction by providing higher quality systems.
Please let me know if you have success with this.
Thank You, Raph30
Jan 22, 2009 | Compaq P4-M, 2.0GHz Pentium 4-M...
Installing adobe premiere elements 7
SSE2 instruction set is a new set of instructions that has been built into the processor chips usually to enhance the performance of the computer. If you are using an older computer/processor, (possibly manufactured before 2001, when the SSE2 was introduced) you may not be able to install the applications that require the SSE2 instruction set on your computer.
Oct 24, 2008 | Computers & Internet
Trying to install Adobe Premier Elements 4 on my computer. Getting a message that states: "SSE2 Instruction set not compatable with my CPU" Help!
If you get this error, your CPU (processor) does not pass the system requirments of Adobe Premier Elements 4. For a list of CPUs supporting SSE2, check out this link:
http://en.wikipedia.org/wiki/SSE2#CPUs_supporting_SSE2
Aug 03, 2008 | Computers & Internet
CPU
Can you be more specific on any details of the error. Here's what SSE2 is: SSE2 extends MMX instructions to operate on XMM registers, allows the programmer to completely avoid the eight 64-bit MMX registers "aliased" on the original IA-32 floating point register stack. This permits mixing integer SIMD and scalar floating point operations without mode switching required between MMX and x87 floating point operations. However, this is overshadowed by the value of being able to perform MMX operations on the wider SSE registers. Other SSE2 extensions include a set of cache-control instructions intended primarily to minimize cache pollution when processing indefinite streams of information, and a sophisticated complement of numeric format conversion instructions. AMD's implementation of SSE2 on the AMD64 (x86-64) platform includes an additional 8 registers, doubling the total number to 16 (XMM0 through XMM15). These additional registers are only visible when running in 64-bit mode. Intel adopted these additional registers as part of their support for x86-64 architecture (officially known as Intel 64) in 2004.
Sep 12, 2007 | Microsoft Windows XP Professional With...
Getting my CPU to support the SSE2 Instruction Set
Hi The SSE2 Instruction set was introduced by Intel in its Pentium 4 range of CPU's. Unfortunatly your pc has a Pentium 3 cpu. The motherboard in your pc does not support the pentium 4 processor. Your only option Im affraid is a new pc
Aug 25, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
110 people viewed this question
Alun Cox
